How do I autostart octoprint in ubuntu server
I installed ubuntu server on an old pc since my pi doesn't work anymore. If I manually start octoprint I can connect to it on port 5000. I created a file for systemd to automatically start it and it works but I don't get all the messages about it starting and I can't connect to it via port 5000. I assume this has to do with the system starting it at startup as user root.
How do I make octoprint start on ubuntu startup but not as user root?
Tried running it manually as a non-root user and it works.
No as it appears to be a problem of what user owns the process.
By what procedure have you installed OctoPrint?
OctoPrint's safe mode has nothing to do with the ownership of OctoPrint.
That's why i said no. Problem was solved by adding a "User=" line in the service definition file.
