I used nano to set parameters to camera:usb_options="-r 1920x1080 -f30, but it still apparently shows as 480p 10 fps. I did get it to be widescreen, but image is still low res and low fps.
Also, how do i access it's local folders over LAN so i can copypaste it's config files?
Change the octoprint webcam config to be the specs i want.
