Hai guys..i'm interested to know about REST API i saw in documation here . But how do i get started ? is there any simple example like Hello world or any simple python script ?
@jithupg I am not sure in what kind of direction do you want to go: Consume current existing APIs, creating a new Plugin which provides REST-APIs, ….?
If you want to create a new Plugin which provides REST-APIs you can take a look into my „Knowledge-Base (https://github.com/OllisGit/OctoPrint-KnowledgeBase/wiki/RestAPI)“ or take a look into a simple Plugin like this: https://github.com/OllisGit/OctoPrint-DisplayLayerProgress-API
Hope that helps
Olli
If you're into Node JS then you might try out my octo-client module. I find it easy to use myself.
For example:
var OctoPrint = require('octo-client');
OctoPrint.printerState(function(ptr){
if (ptr.state.flags.operational) {
var targetHotend1 = ptr.temperature.tool0.target;
console.log(targetHotend1);
