How do I turn off acces controll
#1
Hello, when I first did the setup for octoprint(1.3.10 on a pi) I decided to turn on access control but now I would want to turn it off but I haven't found any "guide" on how to do that. Was hoping that there would be a line in the config.yaml file where I could simply disable it but I didn't find any. So could someone please tell me how to disable it?
#2
Assuming you have your Octoprint server on a secure local-only network, you should be able to do with the accessControl and firstRun changes listed here.
#3
Thanks but the only thing I see under the access control section is the salt id.
#4
You'll have to add those settings.
