I had a mid print crash and I would like to continue the print.
I inspected the terminal log. I did vind where the crash occurred but could not find any z axis indication that would tell me the layer where it stoped.
octoprint Version 1.3.10
Send: N1498167 G1 X183.628 Y121.877 E2.0367*90
Recv: T:195.11 /195.00 B:55.11 /55.00 @:52 B@:0
Recv: ok
Send: N1498168 G1 X183.418 Y122.490 E2.0538*94
Recv: ok
Send: N1498169 G1 X183.096 Y123.289 E2.0765*88
Recv: ok
Send: N1498170 G1 X182.647 Y124.313 E2.1060*93
Recv: ok
Send: N1498171 G1 X181.960 Y125.765 E2.1483*88
Recv: ok
Send: N1498172 G1 X181.394 Y126.882 E2.1812*91
Recv: ok
Send: N1498173 G1 X181.045 Y127.472 E2.1993*95
Recv: ok
Send: N1498174 G1 X180.959 Y127.596 E2.2033*86
Recv: ok
Send: N1498175 G1 X180.568 Y128.027 E2.2186*86
Recv: ok
Send: N1498176 G1 X180.233 Y128.359 E2.2310*91
Recv: ok
Send: N1498177 G1 X179.853 Y128.716 E2.2448*85
Recv: ok
Send: N1498178 G1 X179.368 Y129.134 E2.2616*87
Recv: ok
Send: N1498179 G1 X178.654 Y129.703 E2.2857*84
Recv: ok
Send: N1498180 G1 X178.144 Y130.068 E2.3022*93
Recv: ok
Send: N1498181 G1 X177.669 Y130.380 E2.3172*90
Recv: ok
Send: N1498182 G1 X176.859 Y130.864 E2.3420*86
Recv: ok
Send: N1498183 G1 X176.035 Y131.303 E2.3666*94
Recv: ok
Send: N1498184 G1 X173.692 Y132.432 E2.4351*87
Recv: ok
Send: N1498185 G1 X173.131 Y132.685 E2.4513*86
Recv: ok
Send: N1498186 G1 X172.948 Y132.668 E2.4562*87
Recv: ok
Send: N1498187 G1 X172.690 Y132.758 E2.4634*94
Recv: ok
Send: N1498188 G1 X172.572 Y132.765 E2.4665*84
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N1498189 M105*35
Send: N1498190 M105*43
Send: N1498191 M105*42
Send: N1498192 M105*41
Send: N1498193 M105*40
No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6e917150, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0*125
Recv: start
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: echo: External Reset
Recv: Marlin TH3D U1.R2.7
Recv:
Recv: echo: Last Updated: | Author: (TH3D)
Recv: echo:Compiled: Mar 22 2019
Recv: echo: Free Memory: 3445 PlannerBufferBytes: 1232
Recv: echo:EEPROM version mismatch (EEPROM=? Marlin=V55)
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:SD init fail
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin TH3D U1.R2.7 SOURCE_CODE_URL: PROTOCOL_VERSION:1.0 MACHINE_TYPE:TH3D U1.R2.7 EXTRUDER_COUNT:1 UUID:
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:0
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:BUILD_PERCENT:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: Cap:AUTOREPORT_SD_STATUS:0
Recv: Cap:THERMAL_PROTECTION:1
Recv: ok
Send: M21
Recv: ok
Send: M105
Recv: ok T:195.00 /0.00 B:54.60 /0.00 @:0 B@:0
Send: M155 S2
Recv: ok
Recv: T:193.49 /0.00 B:54.55 /0.00 @:0 B@:0
Recv: T:192.19 /0.00 B:54.33 /0.00 @:0 B@:0
Recv: T:190.68 /0.00 B:54.39 /0.00 @:0 B@:0
Recv: T:189.71 /0.00 B:54.31 /0.00 @:0 B@:0
Recv: T:188.33 /0.00 B:54.13 /0.00 @:0 B@:0
Recv: T:186.43 /0.00 B:54.28 /0.00 @:0 B@:0
Recv: T:185.44 /0.00 B:54.07 /0.00 @:0 B@:0
Recv: T:183.65 /0.00 B:54.09 /0.00 @:0 B@:0
Recv: T:182.36 /0.00 B:53.88 /0.00 @:0 B@:0
Recv: T:180.87 /0.00 B:54.04 /0.00 @:0 B@:0
Recv: T:179.42 /0.00 B:53.88 /0.00 @:0 B@:0
Recv: T:178.35 /0.00 B:53.93 /0.00 @:0 B@:0
Recv: T:176.90 /0.00 B:53.86 /0.00 @:0 B@:0
Recv: T:175.85 /0.00 B:53.77 /0.00 @:0 B@:0
Recv: T:174.39 /0.00 B:53.62 /0.00 @:0 B@:0
Recv: T:173.38 /0.00 B:53.57 /0.00 @:0 B@:0
Recv: T:171.99 /0.00 B:53.41 /0.00 @:0 B@:0
Recv: T:171.02 /0.00 B:53.31 /0.00 @:0 B@:0
Recv: T:169.77 /0.00 B:53.20 /0.00 @:0 B@:0
Recv: T:168.65 /0.00 B:53.11 /0.00 @:0 B@:0
Recv: T:167.43 /0.00 B:52.99 /0.00 @:0 B@:0
Recv: T:166.44 /0.00 B:52.89 /0.00 @:0 B@:0
Recv: T:165.17 /0.00 B:52.84 /0.00 @:0 B@:0
Recv: T:164.03 /0.00 B:52.87 /0.00 @:0 B@:0
Recv: T:162.88 /0.00 B:52.73 /0.00 @:0 B@:0
Recv: T:161.94 /0.00 B:52.62 /0.00 @:0 B@:0
Recv: T:160.79 /0.00 B:52.63 /0.00 @:0 B@:0
Recv: T:159.60 /0.00 B:52.48 /0.00 @:0 B@:0
Recv: T:158.53 /0.00 B:52.54 /0.00 @:0 B@:0
Recv: T:157.69 /0.00 B:52.38 /0.00 @:0 B@:0
Recv: T:156.58 /0.00 B:52.30 /0.00 @:0 B@:0
Recv: T:155.51 /0.00 B:52.33 /0.00 @:0 B@:0
Recv: T:154.54 /0.00 B:52.24 /0.00 @:0 B@:0
Recv: T:153.56 /0.00 B:52.21 /0.00 @:0 B@:0
Recv: T:152.76 /0.00 B:52.10 /0.00 @:0 B@:0
Recv: T:151.86 /0.00 B:52.44 /0.00 @:0 B@:0
Recv: T:150.60 /0.00 B:51.54 /0.00 @:0 B@:0
Recv: T:149.64 /0.00 B:51.89 /0.00 @:0 B@:0
Recv: T:148.86 /0.00 B:51.88 /0.00 @:0 B@:0
Recv: T:147.95 /0.00 B:51.59 /0.00 @:0 B@:0
Recv: T:147.02 /0.00 B:51.52 /0.00 @:0 B@:0
Recv: T:146.10 /0.00 B:51.35 /0.00 @:0 B@:0
Recv: T:145.26 /0.00 B:51.40 /0.00 @:0 B@:0
Recv: T:144.41 /0.00 B:51.34 /0.00 @:0 B@:0
Recv: T:143.50 /0.00 B:51.31 /0.00 @:0 B@:0
Recv: T:142.62 /0.00 B:51.23 /0.00 @:0 B@:0
Recv: T:141.75 /0.00 B:51.16 /0.00 @:0 B@:0
Recv: T:140.88 /0.00 B:51.10 /0.00 @:0 B@:0
Recv: T:140.13 /0.00 B:51.12 /0.00 @:0 B@:0
Recv: T:139.24 /0.00 B:50.97 /0.00 @:0 B@:0
Recv: T:138.38 /0.00 B:50.93 /0.00 @:0 B@:0
Recv: T:137.58 /0.00 B:50.88 /0.00 @:0 B@:0
Recv: T:136.66 /0.00 B:50.82 /0.00 @:0 B@:0
