LG AN-VC300
As with many other cameras, this one is only capable of outputting YUV format, and so results in high CPU usage on the SBC.
I had a look at this topic: USB webcams known to work with mjpg-streamer
And it recommends using v4l2grab as a workaround high CPU usage but I can't seem to get it to work properly. I mean, the recommendation is this:
Start by calling
./mjpg_streamer -i "input_file.so -r -d 0 -f /dev/shm" -o "./output_http.so -w ./www"; it will display and delete new files. Then, call./v4l2grab -c -m -q 50 -o "/dev/shm/"; do not forget the trailing/on this command, which continuously captures jpgs of 50% compression without bound.
The first command fails because -r is not given any valid value but I fixed it by specifying 640x480. However, it still fails with this message:
i: init_VideoIn failed
and if I specify /dev/video1 instead of 0 for the -d argument, it works but eats up all CPU and does not give back control to start the second command.
Nevertheless, I stopped mjpg_streamer and ran v4l2grab -c -m -q 50 -d /dev/video1 -o "/dev/shm/" but this too uses a lot of CPU.
I have seen the following thread too: I see high CPU usage when mjpg-streamer is running
As it does not have the above recommendation, I'm wondering if there actually is a solution other than finding a webcam that outputs MJPEG format directly.
Yes
octoprint-systeminfo-20231031105405.zip (7.0 KB)
Octoprint is running on an Orange Pi Lite with Armbian all in their latest versions
