I'm trying to change the upload folder to use a mounted USB stick.
I've mounted the USB via the fstab file and it maps correctly in SSH at the server. At the pi@octopi cursor the path is /media/files
Putting the path for Upload Folder as /home/pi/media/files shows as valid but doesn't show the files that already exist on the drive.
Raspbian is current version. Octoprint is current version.
I don't think drw-rw-rw will do the job. You probably need x (directory search) permissions, too. Try changing the mode to 775 0r 755 (don't know if group write permissions are necessary).
I did! I really did! And I'm writing up a full tutorial with pictures for the near future but the key was making the mount point in the .octoprint directory I believe.
Create the mount point. I made a ~/.octoprint/USB mount point so I could add folders later
Change the permissions to 777 recursive
Change the owner/user to pi recursive
Create the folders
Update the /etc/fstab file with the mount information
Update the /boot/cmdline.txt to include rootdelay=5 (let the Pi finish loading before mounting)
Update the folders in OctoPrint
Move the files from their current location to the new one (if necessary)
That's kind of a given but the warning will be in the tutorial.
I need to experiment a bit with putting files directly on the drive and how the timelapse functions when writing to the USB. And pulling the timelapse directly off the thumb drive. But in general I think I've got it.
Speaking of timelapses and when to eject... there's kind of an odd thing for the timelapse feature. If you want, say, a 60-second ending of the last frame, don't enter 60 in that dialog box. At the most, just say "1". It will do some sort of conversion into "timelapse seconds". One time I did that and it tool like 24 minutes to finally finish the timelapse at the end.
Hi man! thanks for the guide. I follow all the steps but it doesn't work. I took some pictures to show you. I store two .code files on my mounted usb but still not working. Can you help me? thanks a lot!
Yep, I have done the same a while back, all my print folders reside on a local NAS, along with all the time-lapse folder & co. So that the Raspi does not have to bear the file load. If you have connected a local drive via USB you will most likely not have latency issues, in my NAS case I had to switch from using WIFI to ethernet to make it more reliable and stable.
