Raspberry Pi Camera Module 3
I want to enable HDR feature of RP Cam 3 in Octoprint. The Camera Settings plugin helps in manual focus which is good but it doesn't help with the HDR setting. By enabling HDR I will be able to monitor the print well while using the feature that the camera has.
I tried to use this command as suggested in the PIcamera2 Library manual but I am getting an error.
I tried to reboot the OP in safe mode etc but still cant enable HDR.
Command used: v4l2-ctl --set-ctrl wide_dynamic_range=1 -d /dev/v4l-subdev0
Error:
VIDIOC_S_EXT_CTRLS: failed: Device or resource busy
Error setting controls: Device or resource busy
webcamd.log (64.7 KB)
octoprint.log (588.8 KB)
Running OctoPi RC3 based on bullseye OS.
