When printing multiple objects, with "complete individual object"
Cancelling or pausing (moving carriage to park position) crashes thru other, finished objects.
Tried to look for a variable like "highest_z_so_far_during_this_print"
I can only answer reliably for my own printer, one with a bed which moves up/down. Review this throughout to make sure that it works for your printer. I assume that Z=0 is the maximum distance away from the bed. I further assume that you're using absolute extrusion mode.
Before Pause
{% if pause_position.x is not none %}
; relative XYZE
G91
M83
; retract filament
G1 E-5 F4500
; absolute XYZE
M82
G90
; move to a safe rest position, noting that we move up first, then horizontally
G1 Z0
G1 X0 Y0
{% endif %}
Before Resume
; relative extruder mode + prime nozzle
M83
G1 E-5 F4500
G1 E5 F4500
G1 E5 F4500
; and back to absolute extruder mode
M82 ; Not good if you use relative extrusion
; absolute XYZ mode
G90
; reset extruder audit to what it was earlier
G92 E{{ pause_position.e }} ; Unnecessary if you use relative extrusion
; Here, I'm returning the hotend assembly horizontally first and then vertically
G1 X{{ pause_position.x }} Y{{ pause_position.y }} F4500
G1 Z{{ pause_position.z }} F4500
; reset to feed rate before pause if available
{% if pause_position.f is not none %}G1 F{{ pause_position.f }}{% endif %}
{% endif %}
