Just got Octopi up and running on WiFi. Can't figure out how to turn on extruder when not printing.
Probably very simple
What have you tried so far?
Searching around for a button that turns it on. that's how MatterControl worked. there r buttons to extrude and retract they don't make much sense if you can't heat the hotend up
It's on the first tab you see after the setup wizard. The Temperature tab.
Thanks. Be nice if you could setup a temp and it would save it, or use the temp for the material you have selected
You can add presets in settings.
Thanks. After I used it I realized. New to Octopi, really like it
