How to PAUSE printer when lose Wifi Connection
I'm losing too many works when Octopie lost the wifi connection (I have some outages in my home)
I want to ask to octopie to PAUSE the printer when he lost connection. Currently he's stopping the work and I'm losing the object. But I don't know how to do it.
Logs (syslog, dmesg, ...)
I'm using a Anet A8 Plus, Raspberry Pi 3B+, Connected through wifi (I can't use a cable).
Actually octoprint should continue the print even if it loses the network connection.
Do you mean power outages or wifi outages?
If he has plugins which require the Internet then it probably would behave that way. Oh, if only he could have provided the logs as requested... /TheatricalSigh
At this point I'm honestly wondering if it would be possible to write a Discourse plugin that automatically tells people to post the f...riendly logs if they aren't there yet. So much self sabotage...
Anyone know ruby?
Thank you all!
I found the problem. It was in the cable that connects octoprint to the printer. I was losing connection with the printer and not the server. I just realized it.now!
Thank you all again!
I just realized that the octoprint was losing connection with thw printer and not with thw wifi lol! I repalced the printer cable and now looks fine!
Does this help?
Canned answer replies
