I would like to be able to pause a print as it transitions to a specific z height so I can put nuts or other things into the print then have it continue the print when I click resume. That way I dont have to manually pause the print at just the right second. Is there some plugin i can add to add this functionality, I searched but couldnt find one.
Complete Logs
