How to remotely modify micro SD card
Is there a simple way to modify the octoprint program from a laptop on an installed microSD card without removing it from the Octopi board and reinstalling the entire octoprint program? I need to add a webcam
  • Webcam support is included with OctoPi by default. So no need to install something new.
  • You can access the OctoPi installation via SSH
  • When you pull out the SD card from the shut off Pi and insert ist later again, it starts as usual - except you did not somthing scary to it
what is SSH? Just a beginner here - sorry.
I did not activate the camera option when I set up the Octoprint download.
There is nothing to activate. Just plug in your USB WEB-Cam.
Maybe you have to make some settings.
