Can you run two raspberry pi on two separate printers with the octoprint software ?
Sure
I would change the hostname of one of the the pis tho.
Ssh into one pi, then enter sudo raspi-config
If you are using the Raspberry Pi Imager, you can also set the hostname there (ctrl-shift-x):
Good advice
Do it that way ^^
Thank you for your help. I'm new to octoprint and have one installed on my ender 3. Will I see the two different host names in the octoprint software.
