Hello
I want to set and get tool temperature using REST API
Can I do it
I tried to read all Octoprint API but I did not find the solution and I hope I did not read it correctly
Thank you
Hello
Can I do it
Thank you
From here, it looks like the way to do that would be to send the following to get the temperature of the tools:
GET /api/printer/tool HTTP/1.1
Host: example.com
X-Api-Key: abcdef...
HTTP/1.1 200 OK
"tool0": {
"actual": 214.8821,
"target": 220.0,
"offset": 0
"tool1": {
"actual": 25.3,
"target": null,
"offset": 0
How you do this would depend upon the software language that you're trying to use.
Is there any way to set target temperature ?
Did you read the linked page? It's right there.
Tell me what programming language you're using and I could give a practical example.
