Separate to the main question about the camera - I wouldn't recommend buying a flashforge printer if you want to use OctoPrint. The only way most of them will work a little bit is through a plugin, and even then the communication is not very good at all, allowing only limited access. This printer specifically is not mentioned as supported by the plugin. If you are looking to buy a printer, a flashforge won't work well with OctoPrint.
