I am using a raspberry pi 4B with 4GB of ram.
I installed the latest version of Buster on my pi
I gave it a memory split of 128MB to GPU.
I followed this guide for installing Octoprint onto the pi:
I installed nginx as my reverse-proxy, I followed this guide to install nginx:
https://www.raspberrypi.org/documentation/remote-access/web-server/nginx.md
Here is my reverse-proxy file located in /etc/nginx/sites-enabled/3d-printer.conf, I deleted the default file located in /etc/nginx/sites-enabled:
server {
# webcam port, optional.
location /webcam {
proxy_pass http://localhost:8080/;
location /rtspcam {
proxy_pass http://localhost:8555/;
location /octoprint/ {
proxy_pass http://localhost:5000/;
proxy_set_header Host $http_host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Scheme $scheme;
proxy_set_header X-Script-Name /octoprint;
proxy_http_version 1.1;
client_max_body_size 0;
I did NOT install mjpg-streamer. The reason I did not was because the /dev/video0 device (my raspberry pi camera) once used by a process can not be accessed by another process.
I orignally installed mjpg-streamer and v4l2rtspserver. But these two would not play nice together so I had to find another solution to my camera.
I want my pi camera to stream mjpeg, snap-shots or jpeg and rtsp stream (so I can add it in my surveillance screen with the rest of my cameras)
So I needed three streams coming from one input source, my raspberry pi camera. How to do this?
My solution:
use ffserver to distribute the streams for me. This is how you get ffserver onto your raspberry pi 4B.
Download the ffmpeg 3.4.6 from here (ffserver comes with ffmpeg 3.4.6):
https://ffmpeg.org/download.html#release_3.4
Place the ffmpeg-3.4.6.tar.xz file into /usr/src
From now on, if you see a $
in front of a line it will mean you need to type the command in a command terminal window. Please do not type the '$' symbol with the command or the command will not work.
$cd /usr/src
$sudo tar -xvf ffmpeg-3.4.6.tar.xz
$cd /usr/src
$sudo git clone git://git.videolan.org/x264
$cd x264
$sudo ./configure --host=arm-unknown-linux-gnueabi --enable-static --disable-opencl
if you have a raspberry pi 3B or higher you can use the -j4 otherwise leave it off for raspberry pi 1 or 2
$sudo make -j4
on my raspberry pi 4B it took only 30 minutes to compile
$sudo make install
$cd /usr/src/ffmpeg-3.4.6
$sudo ./configure --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-nonfree --enable-omx --enable-omx-rpi
$sudo make -j4
$sudo make install
NOTE we will use tmp2 as place to save our video, but it will NOT go on the SD card. The video will be save to MEMORY
$sudo mkdir /tmp2
$sudo nano /etc/fstab
add this to /etc/fstab:
tmpfs /tmp2 tmpfs defaults,noatime,mode=1777 0 0
mount tempfs in ram:
$sudo mount /tmp2
create a file with:
$sudo nano /etc/ffserver.conf
and paste this:
# ffserver configuration for an mjpeg stream and rtsp stream
# Adapted from
# https://gist.github.com/peterhellberg/ebfc72147c2009ee720aafe57ce9c141
#/etc/ffserver.conf
HTTPPort 8080
HTTPBindAddress 0.0.0.0
RTSPPort 8555
RTSPBindAddress 0.0.0.0
MaxHTTPConnections 2000
MaxClients 1000
MaxBandwidth 500000
CustomLog -
# Suppress that if you want to launch ffserver as a daemon.
#NoDaemon
<Feed camera.ffm>
File /tmp2/camera.ffm
FileMaxSize 5M
ACL allow 127.0.0.1
ACL allow 192.168.0.0 192.168.255.255
</Feed>
<Stream camera.sdp>
Format rtp
Feed camera.ffm
VideoFrameRate 10
Videosize 480x360
noAudio
ACL allow 127.0.0.1
</Stream>
<Stream camera.mjpeg>
Format mpjpeg
Feed camera.ffm
# Make sure frame rate and size
# match those passed to ffmpeg
VideoFrameRate 10
Videosize 480x360
VideoBitRate 4096
VideoBufferSize 4096
VideoQMin 5
VideoQMax 51
NoAudio
Strict -1
ACL allow 127.0.0.1
</Stream>
<Stream static-camera.jpg>
Format jpeg
Feed camera.ffm
VideoFrameRate 2
VideoIntraOnly
VideoSize 480x360
NoAudio
NoDefaults
Strict -1
ACL allow 127.0.0.1
</Stream>
<Stream stat.html>
Format status
ACL allow localhost
</Stream>
<Redirect index.html>
URL http://www.ffmpeg.org/
</Redirect>
now let's test to see if ffserver will work:
$ffserver -d -f /etc/ffserver.conf
now open another terminal window:
$ffmpeg -input_format mjpeg -video_size 480x360 -framerate 10 -input_format h264 -i /dev/video0 -c:v copy http://localhost:8080/camera.ffm
now goto Chromium and put these two addresses in the address bar:
http://localhost:8080/camera.mjpeg
new Chromium tab:
http://localhost:8080/static-camera.jpg
if you see the camera output then everything is running nicely.
So let's set it up to start automatically:
$sudo nano /etc/systemd/system/ffserver.service
paste this in:
[Unit]
Description=FFMPEG streaming server (ffserver) service
[Service]
User=pi
ExecStart=/usr/local/bin/ffserver -f /etc/ffserver.conf
[Install]
WantedBy=multi-user.target
$sudo nano /etc/systemd/system/ffmpeg.service
paste this in:
[Unit]
Description=FFMPEG transcoder service
After=ffserver.service
[Service]
User=pi
# -video_size and -framerate should match the settings in ffserver.conf
ExecStart=/usr/local/bin/ffmpeg -input_format mjpeg -video_size 480x360 -framerate 10 -input_format h264 -i /dev/video0 -c:v copy -nostats -loglevel panic http://localhost:8080/camera.ffm
[Install]
Then reload systemd and start our new services to ensure they start up properly:
$sudo systemctl --system daemon-reload
$sudo systemctl start ffserver.service
$sudo systemctl start ffmpeg.service
If that goes well, then we can finally configure systemd to run them at startup:
$sudo systemctl enable ffserver.service
$sudo systemctl enable ffmpeg.service
Updating OctoPrint configuration:
Navigate to the OctoPrint settings dialog. In the Webcam & Timelapse section you want these settings:
Stream URL: http://localhost/webcam/camera.mjpeg
Snapshot URL: http://localhost/webcam/static-camera.jpg
RTSP URL: rtsp://localhost:8555/camera.sdp
If you would like to control all the stream through Octoprint:
$cd /home/pi/scripts
$nano webcamStreams
past this in:
#!/bin/bash
# Start / stop webcam streamer daemons
case "$1" in
start)
sudo service ffserver start >/dev/null 2>&1 &
sudo service ffmpeg start >/dev/null 2>&1 &
echo "$0: started"
stop)
sudo service ffmpeg stop >/dev/null 2>&1 &
sudo service ffserver stop >/dev/null 2>&1 &
echo "$0: stopped"
echo "Usage: $0 {start|stop}" >&2
esac
$cd /home/pi/.octoprint
$nano config.yaml
paste this in:
system:
actions:
- action: streamon
command: /home/pi/scripts/webcamStreams start
confirm: false
name: Start video streams
- action: streamoff
command: sudo /home/pi/scripts/webcamStreams stop
confirm: false
name: Stop video streams
$sudo reboot
when the system reboots you will have the following:
on http://localhost, you will find the octoprint UI
on http://localhost/webcam/camera.mjpeg , you will find the Stream URL
on http://localhost/webcam/static-camera.jpg , you will find the Snapshot URL
on rtsp://localhost:8555/camera.sdp, you will find the RTSP URL
In Octorprint if you go to the top menu under the Power button, you will see two entries "Turn off the video streams" and "Turn on the video streams". These selection will give you control over all three streams. So they are all on or they are all off. On boot of your system, all three streams will be ON.
I noticed I am only using 19% CPU and my tempurature on my pi is at 44 degree C (I have a heat sink and active fan on the pi 4B)
I hope this helps someone. If anyone notices errors please point them out. But my setup is working at this time.
Happy and safe 3d printing!
