ArduCam IMX708
What is the problem
The camera is not working. I've seen a lot of people say how you have to update the pi firmware (pi4 is what i have) so how do i do that there's no clear beginner video i can understand. i already have octoprint installed i do have a back up saved so do i put the normal software back on or how do i do this bc i have no screen for this pi so can i use ssh for this?? im so lost and i don't want to spend more money if i already have a camera .
None im scard ill brick it
No all the other similar concerns said that sis help so didn't bother
N/A
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 3968638976
env.os.bits: 32
env.os.id: linux
env.os.platform: Linux-6.6.51+rpt-rpi-v7l-armv7l-with-glibc2.36
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.1.0
env.plugins.pi_support.octopiuptodate_build: 1.1.0-1.11.1-20250513134411
env.plugins.pi_support.octopiuptodate_build_short: 2025.05.13.134411
env.python.pip: 25.0.1
env.python.version: 3.11.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2025-05-26T05:33:22Z
octoprint.last_safe_mode.reason: incomplete_startup
octoprint.safe_mode: False
octoprint.version: 1.11.1
systeminfo.generated: 2025-06-04T04:58:41Z
systeminfo.generator: zipapi
ender 3 s1 running professional software
