Getting "OctoPrint server is currently not running" page
Reinstall in teminal, want to avoid having to re flash and learn what is going on( i know reflashing will work)
Logs
2020-03-04 18:11:58,418 - octoprint.startup - INFO - *************************** ***************************************************
2020-03-04 18:11:58,419 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-03-04 18:11:58,419 - octoprint.startup - INFO - *************************** ***************************************************
2020-03-04 18:13:05,969 - octoprint.startup - INFO - We don't appear to be onlin e, not fetching plugin blacklist
2020-03-04 18:13:07,113 - octoprint.util.connectivity_checker - INFO - Connectiv ity changed from offline to online
2020-03-04 18:13:07,371 - octoprint.plugin.core - INFO - Loading plugins from /h ome/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint /plugins and installed plugin packages...
2020-03-04 18:13:13,252 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2020-03-04 18:13:13,698 - octoprint.plugin.core - INFO - Plugin Prusa Leveling G uide (1.0.7) is disabled.
2020-03-04 18:13:13,766 - octoprint.plugin.core - INFO - Plugin FileManager (0.1 .3) is disabled.
2020-03-04 18:13:13,887 - octoprint.plugin.core - INFO - Plugin Enclosure Plugin (4.13.1) is disabled.
2020-03-04 18:13:13,939 - py.warnings - WARNING - /home/pi/oprint/local/lib/pyth on2.7/site-packages/octoprint_cancelobject/__init__.py:13: ExtDeprecationWarning : Importing flask.ext.login is deprecated, use flask_login instead.
from flask.ext.login import current_user
2020-03-04 18:13:14,819 - octoprint.plugin.core - INFO - Found 32 plugin(s) prov iding 28 mixin implementations, 53 hook handlers
2020-03-04 18:13:14,970 - octoprint.server.heartbeat - INFO - Starting server he artbeat, 900.0s interval
2020-03-04 18:13:15,486 - octoprint.server - INFO - Intermediary server started
2020-03-04 18:13:15,487 - octoprint.plugin.core - INFO - Loading plugins from /h ome/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint /plugins and installed plugin packages...
2020-03-04 18:13:15,603 - octoprint.plugin.core - INFO - Found 32 plugin(s) prov iding 28 mixin implementations, 53 hook handlers
2020-03-04 18:13:15,637 - octoprint.filemanager.storage - INFO - Initializing th e file metadata for /home/pi/.octoprint/uploads...
2020-03-04 18:13:15,830 - octoprint.filemanager.storage - INFO - ... file metada ta for /home/pi/.octoprint/uploads initialized successfully.
2020-03-04 18:13:15,833 - octoprint.server - INFO - Added new permission from pl ugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need (method='role', value=u'plugin_action_command_prompt_interact')")
2020-03-04 18:13:15,834 - octoprint.server - INFO - Added new permission from pl ugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', valu e=u'plugin_announcements_read')")
2020-03-04 18:13:15,835 - octoprint.server - INFO - Added new permission from pl ugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', va lue=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announce ments_read')")
2020-03-04 18:13:15,836 - octoprint.server - INFO - Added new permission from pl ugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_ appkeys_admin')")
2020-03-04 18:13:15,837 - octoprint.server - INFO - Added new permission from pl ugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_b ackup_access')")
2020-03-04 18:13:15,838 - octoprint.server - INFO - Added new permission from pl ugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin _logging_manage')")
2020-03-04 18:13:15,838 - octoprint.server - INFO - Added new permission from pl ugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u' plugin_pi_support_check')")
2020-03-04 18:13:15,839 - octoprint.server - INFO - Added new permission from pl ugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', va lue=u'plugin_pluginmanager_manage')")
2020-03-04 18:13:15,840 - octoprint.server - INFO - Added new permission from pl ugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', v alue=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_plugin manager_manage')")
2020-03-04 18:13:15,841 - octoprint.server - INFO - Added new permission from pl ugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(me thod='role', value=u'plugin_printer_safety_check_display')")
2020-03-04 18:13:15,849 - octoprint.server - INFO - Added new permission from pl ugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', v alue=u'plugin_softwareupdate_check')")
2020-03-04 18:13:15,850 - octoprint.server - INFO - Added new permission from pl ugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-03-04 18:13:15,864 - octoprint.printer.standard - INFO - Using print time e stimator provided by PrusaETAOverride
2020-03-04 18:13:15,873 - octoprint.plugins.cancelobject - INFO - No beforegcode defined
2020-03-04 18:13:15,874 - octoprint.plugins.cancelobject - INFO - No aftergcode defined
2020-03-04 18:13:15,980 - octoprint.plugins.softwareupdate - INFO - Loaded versi on cache from disk
2020-03-04 18:13:16,802 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin /python2 -m pip" as command to invoke pip
2020-03-04 18:13:17,431 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-03-04 18:13:17,433 - octoprint.util.pip - INFO - pip installs to /home/pi/o print/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, v irtual env -> yes
2020-03-04 18:13:17,434 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-03-04 18:13:17,438 - octoprint.plugin.core - INFO - Initialized 28 plugin i mplementation(s)
2020-03-04 18:13:17,452 - octoprint.plugin.core - INFO - 32 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site- packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/o ctoprint/plugins/announcements
| !Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packa ges/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packag es/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octo print/plugins/backup
| Bed Visualizer (0.1.11) = /home/pi/oprint/local/lib/python2.7/site-packages/o ctoprint_bedlevelvisualizer
| Cancel Objects (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/oc toprint_cancelobject
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint /plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/p lugins/discovery
| DisplayZ (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprin t_displayz
| Dragon Order (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octo print_dragon_order
| !Enclosure Plugin (4.13.1) = /home/pi/oprint/local/lib/python2.7/site-packages /octoprint_enclosure
| Error Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octopr int/plugins/errortracking
| !FileManager (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octop rint_filemanager
| Fullscreen Plugin (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages /octoprint_fullscreen
| HeaterTimeout (0.0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/oct oprint_HeaterTimeout
| Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plu gins/logging
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/pl ugins/loginui
| MultiCam (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprin t_multicam
| Navbar Temperature Plugin (0.11) = /home/pi/oprint/local/lib/python2.7/site-p ackages/octoprint_navbartemp
| Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octopri nt_octolapse
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/oct oprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octopr int/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/ octoprint/plugins/printer_safety_check
| Prusa ETA override Plugin (0.1.1) = /home/pi/oprint/local/lib/python2.7/site- packages/octoprint_PrusaETAOverride
| !Prusa Leveling Guide (1.0.7) = /home/pi/oprint/local/lib/python2.7/site-packa ges/octoprint_PrusaLevelingGuide
| Resource Monitor (0.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/ octoprint_resource_monitor
| Simple Emergency Stop (0.2.5) = /home/pi/oprint/local/lib/python2.7/site-pack ages/octoprint_simpleemergencystop
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octop rint/plugins/softwareupdate
| Themeify (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprin t_themeify
| TouchUI (0.3.13) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprin t_touchui
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octop rint/plugins/virtual_printer
2020-03-04 18:13:17,462 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 4096270336
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-03-04 18:13:17,689 - octoprint.server - INFO - Reset webasset folder /home/ pi/.octoprint/generated/webassets...
2020-03-04 18:13:17,708 - octoprint.server - INFO - Reset webasset folder /home/ pi/.octoprint/generated/.webassets-cache...
2020-03-04 18:13:17,822 - octoprint.plugins.octolapse - INFO - Octolapse is load ing assets.
2020-03-04 18:13:18,518 - octoprint.server - INFO - Shutting down intermediary s erver...
2020-03-04 18:13:18,997 - octoprint.server - INFO - Intermediary server shut dow n
2020-03-04 18:13:19,001 - octoprint.events - INFO - Processing startup event, th is is our first event
2020-03-04 18:13:19,002 - octoprint.events - INFO - Adding 1 events to queue tha t were held back before startup event
2020-03-04 18:13:19,017 - octoprint.server - INFO - Autoconnect on startup is co nfigured, trying to connect to the printer...
2020-03-04 18:13:19,018 - octoprint.filemanager - INFO - Adding backlog items fr om all storage types to analysis queue...
2020-03-04 18:13:19,023 - octoprint.filemanager - INFO - Added 0 items from stor age type "local" to analysis queue
2020-03-04 18:13:19,057 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-03-04 18:13:19,756 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-03-04 18:13:19,859 - octoprint.server - INFO - Trying to connect to configu red serial port /dev/ttyACM0
2020-03-04 18:13:19,890 - octoprint.server.util.watchdog - INFO - Running initia l scan on watched folder...
2020-03-04 18:13:19,893 - octoprint.server.util.watchdog - INFO - ... initial sc an done.
2020-03-04 18:13:19,898 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2020-03-04 18:13:19,900 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2020-03-04 18:13:19,904 - octoprint.util.comm - INFO - M110 detected, setting cu rrent line number to 0
2020-03-04 18:13:19,906 - octoprint.plugins.discovery - INFO - Registered 'OctoP rint instance "MK3s"' for _http._tcp
2020-03-04 18:13:19,917 - octoprint.plugins.discovery - INFO - Registered 'OctoP rint instance "MK3s"' for _octoprint._tcp
2020-03-04 18:13:19,921 - octoprint.plugins.discovery - INFO - Registered OctoPr int instance "MK3s" for SSDP
2020-03-04 18:13:19,955 - octoprint.server - INFO - Listening on http://127.0.0. 1:5000
2020-03-04 18:13:19,958 - octoprint.plugins.octolapse - INFO - Loading existing settings file from: /home/pi/.octoprint/data/octolapse/settings.json.
2020-03-04 18:13:20,087 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-03-04 18:13:20,731 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin /python2 -m pip" as command to invoke pip
2020-03-04 18:13:20,732 - octoprint.util.pip - INFO - pip installs to /home/pi/o print/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, v irtual env -> yes
2020-03-04 18:13:20,738 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-03-04 18:13:20,908 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-03-04 18:13:20,925 - octoprint.plugins.HeaterTimeout - INFO - Starting up.. .
2020-03-04 18:13:20,926 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrin t-BedLevelVisualizer loaded!
2020-03-04 18:13:20,927 - octoprint.plugins.multicam - INFO - MultiCam Loaded! ( more: [{'URL': '/webcam/?action=stream', 'isButtonEnabled': False, 'name': 'Defa ult'}])
2020-03-04 18:13:20,930 - octoprint.plugins.navbartemp - INFO - Broadcom detecte d
2020-03-04 18:13:20,933 - octoprint.plugins.themeify - INFO - Themeify initializ ed.
2020-03-04 18:13:20,950 - octoprint.util.comm - INFO - M110 detected, setting cu rrent line number to 0
2020-03-04 18:13:21,847 - octoprint.server.preemptive_cache - INFO - Preemptivel y caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url ': 'http://192.168.201.4/'}
2020-03-04 18:13:23,244 - octoprint.util.comm - INFO - M110 detected, setting cu rrent line number to 0
2020-03-04 18:13:23,245 - octoprint.util.comm - INFO - Got a resend request for line 1 which is also our current line. It looks like we just handled a reset and this is a left over of this
2020-03-04 18:13:23,252 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-03-04 18:13:23,259 - octoprint.util.comm - INFO - M110 detected, setting cu rrent line number to 0
2020-03-04 18:13:23,386 - octoprint.util.comm - INFO - Printer reports firmware name "Prusa-Firmware 3.8.1 based on Marlin"
2020-03-04 18:13:26,420 - octoprint.server.util.sockjs - INFO - New connection f rom client: ::ffff:192.168.201.1
2020-03-04 18:13:26,594 - octoprint.server.util.flask - INFO - Passively logging in user Buzkill from ::ffff:192.168.201.1
2020-03-04 18:13:26,600 - octoprint.access.users - INFO - Logged in user: Buzkil l
2020-03-04 18:13:26,662 - octoprint.server.util.sockjs - INFO - User Buzkill log ged in on the socket from client ::ffff:192.168.201.1
2020-03-04 18:13:32,017 - octoprint.server.preemptive_cache - INFO - ... done in 10.17s
2020-03-04 18:13:32,018 - octoprint.server.preemptive_cache - INFO - Preemptivel y caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url ': 'http://[::1]/'}
2020-03-04 18:13:33,884 - octoprint.server.preemptive_cache - INFO - ... done in 1.87s
2020-03-04 18:15:34,588 - octoprint.server - INFO - Shutting down...
2020-03-04 18:15:34,953 - octoprint.events - INFO - Processing shutdown event, t his will be our last event
2020-03-04 18:15:34,956 - octoprint.events - INFO - Event loop shut down
2020-03-04 18:15:34,970 - octoprint.plugins.HeaterTimeout - INFO - Shutting down ...
2020-03-04 18:15:34,971 - octoprint.server - INFO - Goodbye!
python:
pip: 19.3.1
version: 2.7.16
thank you very much Foosel! You're a wonderful person!
). Can you please mark the thread as solved then, by clicking on
on the solving reply?
