I have been running octoprint for about a month with no issues. Tody my internet provider made some changed to our internet and WiFi. The name of the network was changes. I took out the SD care and opened the octopi-wpa-supplicant.txt in Notepad++ I changed the name and then saved. I put the SD card back in and i can not get in using putty. I am not sure what to do. I put the IP address that I had been using for octoprint into my browser, but it will not connect.
Changed the network name in octopi-wpa-supplicant.txt
tried multiple times to get into octoprint using putty.
Hooked up with Ethernet cable.
looked in my router for the IP address this is what is where the IP address should be fd9e:f6ca:85c3:0:2503:27e8:0:a66
I can't get into octopi at all
NA
Complete Logs
