When i try to log in via google Chome on Android (Samsung Galaxy S7) i keep getting the error invalid login / password.
When don on a laptop the same credentials work.
I have created another account and still cannot log in.
Check my password and case
Reset my password
Restarted octoprint
Restarted my PI
Disconnected my phone from setork and re-connected.
If i disable the force login then i can access octopi.
Octoprint.log
2019-03-05 10:29:12,968 - octoprint.startup - INFO - ******************************************************************************
2019-03-05 10:29:12,970 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-03-05 10:29:12,971 - octoprint.startup - INFO - ******************************************************************************
2019-03-05 10:29:14,026 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-03-05 10:29:14,273 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-03-05 10:29:14,310 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-03-05 10:29:15,016 - octoprint.plugin.core - INFO - Plugin Virtual Printer is disabled.
2019-03-05 10:29:15,163 - octoprint.plugin.core - INFO - Plugin Discovery is disabled.
2019-03-05 10:29:15,511 - octoprint.plugin.core - INFO - Plugin Force Login is disabled.
2019-03-05 10:29:16,431 - octoprint.plugin.core - INFO - Found 22 plugin(s) providing 19 mixin implementations, 22 hook handlers
2019-03-05 10:29:16,532 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-03-05 10:29:16,558 - octoprint.server - INFO - Intermediary server started
2019-03-05 10:29:16,558 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-03-05 10:29:17,156 - octoprint.plugin.core - INFO - Found 22 plugin(s) providing 19 mixin implementations, 22 hook handlers
2019-03-05 10:29:17,226 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-03-05 10:29:17,797 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-03-05 10:29:17,830 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-03-05 10:29:17,979 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-03-05 10:29:19,477 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-03-05 10:29:20,996 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-03-05 10:29:20,997 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-03-05 10:29:20,998 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-03-05 10:29:21,005 - octoprint.plugin.core - INFO - Initialized 19 plugin implementation(s)
2019-03-05 10:29:21,022 - octoprint.plugins.psucontrol - INFO - Using GPIO for On/Off
2019-03-05 10:29:21,023 - octoprint.plugins.psucontrol - INFO - Using internal tracking for PSU on/off state.
2019-03-05 10:29:21,023 - octoprint.plugins.psucontrol - INFO - Running RPi.GPIO version 0.6.5
2019-03-05 10:29:21,025 - octoprint.plugins.psucontrol - INFO - Using GPIO for On/Off
2019-03-05 10:29:21,026 - octoprint.plugins.psucontrol - INFO - Configuring GPIO for pin 11
2019-03-05 10:29:21,032 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
| AstroPrint (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_astroprint
| Automatic Shutdown (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_automaticshutdown
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| !Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
| !Force Login (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin
| Malyan/Monoprice Connection Fix (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_malyan_connection_fix
| OctoPrint Anywhere (0.9.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
| PortLister (0.1.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_portlister
| PSU Control (0.1.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_psucontrol
| TouchUI (0.3.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_touchui
| !Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-03-05 10:29:21,050 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 386437120
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model A Plus Rev 1.0
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-03-05 10:29:21,061 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-03-05 10:29:21,077 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-03-05 10:29:21,388 - octoprint.server - INFO - Shutting down intermediary server...
2019-03-05 10:29:21,815 - octoprint.server - INFO - Intermediary server shut down
2019-03-05 10:29:21,818 - octoprint.events - INFO - Processing startup event, this is our first event
2019-03-05 10:29:21,819 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2019-03-05 10:29:21,821 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-03-05 10:29:21,877 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-03-05 10:29:22,202 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-03-05 10:29:22,220 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-03-05 10:29:22,684 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-03-05 10:29:23,184 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.151
2019-03-05 10:29:23,260 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:29:23,358 - octoprint.server.util.flask - INFO - Passively logging in user newland from ::ffff:192.168.5.151
2019-03-05 10:29:23,374 - octoprint.server.util.sockjs - INFO - User newland logged in on the socket from client ::ffff:192.168.5.151
2019-03-05 10:29:23,822 - octoprint.plugins.astroprint - INFO - Connected to astroprint service
2019-03-05 10:29:24,242 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.151
2019-03-05 10:29:24,290 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.151
2019-03-05 10:29:24,384 - octoprint.server.util.flask - INFO - Passively logging in user newland from ::ffff:192.168.5.151
2019-03-05 10:29:24,404 - octoprint.server.util.sockjs - INFO - User newland logged in on the socket from client ::ffff:192.168.5.151
2019-03-05 10:29:24,943 - octoprint.plugins.portlister - INFO - Port Lister () {}
2019-03-05 10:29:24,959 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-03-05 10:29:25,302 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-03-05 10:29:26,569 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-03-05 10:29:26,571 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-03-05 10:29:26,572 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-03-05 10:29:26,669 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http:// 192.168.5.235/'}
2019-03-05 10:29:27,097 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 386437120, 'octopi_version': '0.16.0', 'version': u'1.3.10', 'pip': '19.0.1', 'cores': 4, 'freq': 1400.0, 'pi_model': 'Raspberry Pi 3 Model A Plus Rev 1.0', 'os': 'linux'}
2019-03-05 10:29:28,831 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.151
2019-03-05 10:29:28,898 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.151
2019-03-05 10:29:28,992 - octoprint.server.util.flask - INFO - Passively logging in user newland from ::ffff:192.168.5.151
2019-03-05 10:29:29,008 - octoprint.server.util.sockjs - INFO - User newland logged in on the socket from client ::ffff:192.168.5.151
2019-03-05 10:29:45,719 - octoprint.server.preemptive_cache - INFO - ... done in 19.05s
2019-03-05 10:29:45,720 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'https: // 192.168.5.235/'}
2019-03-05 10:29:45,743 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.151
2019-03-05 10:29:49,249 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.151
2019-03-05 10:29:49,435 - octoprint.server.util.flask - INFO - Passively logging in user newland from ::ffff:192.168.5.151
2019-03-05 10:29:51,796 - octoprint.server.preemptive_cache - INFO - ... done in 6.08s
2019-03-05 10:29:53,016 - octoprint.server.util.sockjs - INFO - User newland logged in on the socket from client ::ffff:192.168.5.151
2019-03-05 10:30:01,318 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:30:05,297 - tornado.access - WARNING - 403 POST /api/plugin/anywhere (::ffff:192.168.5.220) 14.09ms
2019-03-05 10:30:05,856 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:30:07,098 - tornado.access - WARNING - 403 POST /api/plugin/automaticshutdown (::ffff:192.168.5.220) 684.62ms
2019-03-05 10:30:07,117 - tornado.access - WARNING - 403 POST /api/plugin/psucontrol (::ffff:192.168.5.220) 214.65ms
2019-03-05 10:30:26,366 - octoprint.plugins.psucontrol - INFO - Switching PSU On
2019-03-05 10:30:27,835 - octoprint.plugins.portlister - INFO - on_port_created connection_options {'portPreference': None, 'autoconnect': True, 'baudrates': [250000, 230400, 115200, 57600, 38400, 19200, 9600], 'ports': ['/dev/ttyUSB0'], 'baudratePreference': None}
2019-03-05 10:30:27,836 - octoprint.plugins.portlister - INFO - Checking if /dev/ttyUSB0 is in ['/dev/ttyUSB0']
2019-03-05 10:30:27,843 - octoprint.plugins.portlister - INFO - autoconnect_delay 20
2019-03-05 10:30:32,220 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:30:34,425 - tornado.access - WARNING - 403 POST /api/plugin/anywhere (::ffff:192.168.5.220) 29.02ms
2019-03-05 10:30:34,739 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:30:35,482 - tornado.access - WARNING - 403 POST /api/plugin/automaticshutdown (::ffff:192.168.5.220) 429.77ms
2019-03-05 10:30:35,502 - tornado.access - WARNING - 403 POST /api/plugin/psucontrol (::ffff:192.168.5.220) 167.27ms
2019-03-05 10:30:47,853 - octoprint.plugins.portlister - INFO - do_auto_connect
2019-03-05 10:30:47,856 - octoprint.plugins.portlister - INFO - realpath match
2019-03-05 10:30:47,952 - octoprint.plugins.portlister - ERROR - Exception in do_auto_connect TypeError: '%d format: a number is required, not NoneType' @ init.py:do_auto_connect:71
2019-03-05 10:31:02,967 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:31:04,049 - tornado.access - WARNING - 403 POST /api/plugin/anywhere (::ffff:192.168.5.220) 14.07ms
2019-03-05 10:31:04,219 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:31:05,315 - tornado.access - WARNING - 403 POST /api/plugin/automaticshutdown (::ffff:192.168.5.220) 666.69ms
2019-03-05 10:31:05,333 - tornado.access - WARNING - 403 POST /api/plugin/psucontrol (::ffff:192.168.5.220) 387.93ms
2019-03-05 10:31:23,844 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:31:24,587 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:31:26,220 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:31:28,703 - tornado.access - WARNING - 403 POST /api/plugin/anywhere (::ffff:192.168.5.220) 15.00ms
2019-03-05 10:31:28,935 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.220
2019-03-05 10:31:29,937 - tornado.access - WARNING - 403 POST /api/plugin/automaticshutdown (::ffff:192.168.5.220) 649.85ms
2019-03-05 10:31:29,955 - tornado.access - WARNING - 403 POST /api/plugin/psucontrol (::ffff:192.168.5.220) 401.91ms
2019-03-05 10:32:27,405 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-03-05 10:32:27,500 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2019-03-05 10:32:27,509 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2019-03-05 10:32:28,519 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:50,943 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:51,942 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:52,971 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:53,966 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:54,985 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:55,010 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2019-03-05 10:32:55,041 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:32:55,078 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.8 (Github)"
2019-03-05 10:32:55,106 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2019-03-05 10:32:55,406 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': u'AUTO', 'firmware_name': 'Marlin 1.1.8 (Github)'}
2019-03-05 10:33:05,471 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2019-03-05 10:33:05,522 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-03-05 10:33:06,519 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': 'local', 'file': '2aea8123ef1b9e576cc66ee0c777c2540d2f873e'}
2019-03-05 10:33:07,568 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2019-03-05 10:35:30,459 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.220
2019-03-05 10:36:03,853 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2019-03-05 10:44:16,535 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-03-05 10:44:26,944 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {}
