sorry,my english is poor ,i copy the text someone like me
I am having the issue of not connecting...timing out...offline.
I have Prusa MK3S+ connected via USB cable.
I have changed Cat 5 cables.
I can monitor my webcam, both from my pc and iPhone. I cannot connect, tranfer, nor control from either.
I have rebooted both the Raspberry Pi and PC, tried different USB ports on Raspberry
Also tried in "safe mode"
serial port /dev/ttyACM0
Baudrate 115200
yes
no
octoprint-systeminfo-20220815104150.zip (44.6 KB)
Hello @ace450586793 !
Have you set the Prusa firmware for using USB?
For USB, you have to set off
thank you for reply
my printer RPi port is off
Just for clarification:
CAT 5 cables are for LAN connection and do not influence the USB connection of the Pi to the printer.
Have you tried different USB cables too?
yes,i have 2 cat5 cables and i have changed it
You may try more than two or three. Power only cables can't be distinguished from data cables on the first sight.
sorry,I said it wrong
i have changed 2 data cables already.
and it does't work
You may try more.
Some users found a working one with 1 out of 6.
You can recognize a good data cable by the ferrite beads at the ends and that they a thicker than a power only cable.
but my data cables can connect before
Can you then share the systeminfo bundle
You may try to connect to Pronterface running on your PC
Hello @Benoit_Naud !
The OP never mentioned that.
From the log:
| plugins:
| pi_support:
| octopi_version: 1.0.0
| throttle_check_enabled: true
| throttle_check_functional: true
| throttle_state: '0x0'
The OP has a connection to the Pi. So why that?
my mistake sorry , I read too fast
I get confused with the cat5 cable and the rpi zero setup om MK3S
I believe you are confusing us by using "cat5 cable" when we think you mean "USB cable". The connectors are vastly different so you should be able to tell them apart and I don't believe the MK3S+ has an ethernet cable connection. Perhaps you can take a picture of the ends of the cable and post it here?
sorry , my english is bad. i mean i have changed USB cable but it does't work
Hello, I connected mk3s + to the PC, and then prompted that the hardware could not be recognized. Then I rewrote the driver and official firmware for mk3s +, and octoprint can be connected. It's been used normally for several days. Today, it can't be connected as before
