I can't connect to my printer even though it is connected via USB, this happened recently,
2023-05-01 20:13:12,026 - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-05-01 20:13:12,110 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyS0@115200, /dev/ttyS0@250000, /dev/ttyS0@230400, /dev/ttyS0@57600, /dev/ttyS0@38400, /dev/ttyS0@19200, /dev/ttyS0@9600
2023-05-01 20:13:12,112 - Trying port /dev/ttyS0, baudrate 115200
2023-05-01 20:13:12,130 - Connecting to port /dev/ttyS0, baudrate 115200
2023-05-01 20:13:12,178 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:12,185 - Connected to: Serial<id=0x65802088, open=True>(port='/dev/ttyS0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2023-05-01 20:13:12,192 - Send: N0 M110 N0*125
2023-05-01 20:13:14,217 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:14,253 - Send: N0 M110 N0*125
2023-05-01 20:13:16,283 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:16,317 - Send: N0 M110 N0*125
2023-05-01 20:13:18,330 - Trying port /dev/ttyS0, baudrate 250000
2023-05-01 20:13:18,332 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:18,348 - Send: N0 M110 N0*125
2023-05-01 20:13:20,359 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:20,375 - Send: N0 M110 N0*125
2023-05-01 20:13:22,385 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:22,402 - Send: N0 M110 N0*125
2023-05-01 20:13:24,411 - Trying port /dev/ttyS0, baudrate 230400
2023-05-01 20:13:24,413 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:24,427 - Send: N0 M110 N0*125
2023-05-01 20:13:26,437 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:26,449 - Send: N0 M110 N0*125
2023-05-01 20:13:28,459 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:28,473 - Send: N0 M110 N0*125
2023-05-01 20:13:30,485 - Trying port /dev/ttyS0, baudrate 57600
2023-05-01 20:13:30,487 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:30,506 - Send: N0 M110 N0*125
2023-05-01 20:13:30,511 - Recv:  „ð „ð „ð „°"ÿ „ð „ð „ð „0 þ „ð „ð „ð „°"ÿa  þa  †`àa  þa  †`
€a  þa  †`à(` (` (` (@ (` (` (` (` (@  ü þ þ þ ¾
2023-05-01 20:13:30,514 - WARNThe received line contains at least one null byte character at position 0, this hints at some data corruption going on
2023-05-01 20:13:32,532 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:32,544 - Send: N0 M110 N0*125
2023-05-01 20:13:34,556 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:34,570 - Send: N0 M110 N0*125
2023-05-01 20:13:34,578 - Recv:  þ þ þ þ þ ~ þ þ þ þ þ þ ¾
2023-05-01 20:13:34,580 - WARNThe received line contains at least one null byte character at position 0, this hints at some data corruption going on
2023-05-01 20:13:36,594 - Trying port /dev/ttyS0, baudrate 38400
2023-05-01 20:13:36,596 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:36,618 - Send: N0 M110 N0*125
2023-05-01 20:13:38,630 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:38,648 - Send: N0 M110 N0*125
2023-05-01 20:13:40,659 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:40,672 - Send: N0 M110 N0*125
2023-05-01 20:13:42,685 - Trying port /dev/ttyS0, baudrate 19200
2023-05-01 20:13:42,687 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:42,705 - Send: N0 M110 N0*125
2023-05-01 20:13:44,701 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:44,714 - Send: N0 M110 N0*125
2023-05-01 20:13:46,714 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:46,725 - Send: N0 M110 N0*125
2023-05-01 20:13:48,726 - Trying port /dev/ttyS0, baudrate 9600
2023-05-01 20:13:48,727 - Handshake attempt #1 with timeout 2.0s
2023-05-01 20:13:48,744 - Send: N0 M110 N0*125
2023-05-01 20:13:50,741 - Handshake attempt #2 with timeout 2.0s
2023-05-01 20:13:50,758 - Send: N0 M110 N0*125
2023-05-01 20:13:52,757 - Handshake attempt #3 with timeout 2.0s
2023-05-01 20:13:52,770 - Send: N0 M110 N0*125
2023-05-01 20:13:54,769 - Changing monitoring state from "Detecting serial connection" to "Error"
2023-05-01 20:13:54,815 - Changing monitoring state from "Error" to "Offline after error"
2023-05-01 20:13:54,855 - Connection closed, closing down monitor
Have you tried different USB cables?
Also, what printer are you using?
Can you also share the systeminfo bundle?
It seems to be ok, I used tape to shield the 5V pin of the USB to prevent the Raspberry Pi from saying that it is undervoltage. Unable to connect to printer.
But have you actually tried using a different USB cable?
