I can't connect to my Raspberry Pi 3B+. Putty gives me "timed out connection", typing IP into a browser gives me "cannot load a page".
My problem seems a little strange. I've enabled SSH in config, there are both laptop and the raspberry connected to the same ethernet network, (nevertheless I changed also credentials for a wifi but anyway), command prompt on windows gives me pings from an raspberry IP (I checked IP through connecting raspberry to the monitor).
Octoprint 0.15.1
What's the diffrence between Octoprint and Octopi versions?
Prusa i3 mk3, newest 3.3.1 firmware
How to get logs if I can't connect is it possible?
