I can't install any plugins. error: subprocess-exited-with-error - exit code: 255
I am unable to install any plugins either via the plugin manager or cli.
Tried installing plugins both through the manger and ssh
N/A
octoprint-systeminfo-20230420213714.zip (6.3 KB)
Version 1.8.7, Debian 11, Ender-3 S1 Pro, Chrome
Γ— Getting requirements to build wheel did not run successfully.
exit code: 255
Could not import OctoPrint's setuptools, are you sure you are running that under the same python installation that OctoPrint is installed under?
I get the same errors both via the manger and cli
plugin_pluginmanager_console (2).log (8.2 KB)
Did you get an answer to this? I have the same issue.
Can you try the same solution I put in this other post?
This worked! Thank you so much for taking the time to post the answer here. I did see your post when I was searching for the solution earlier.
Yes, the solution Charlie posted works for me.
