@alex foosel would like you to also include the content of the octoprint.log here as well. The little button next to the trashcan allows you to download the log file to your computer first. You'd then use the upload icon here to include it with your post.
If you say "in octoprint i had an error..." and you don't tell us what the error was exactly, then all we can do is guess. It's better to copy/paste the error here for us.
I had reinstal octoprint , now it is working , also the plugin and enthernet is working , but wen i want to move or to print , my 3d printer dont do nothing , in octoprint i had an error that printer healted , also wen i try on my tft28 touchscreen , it dont do nothing , juat now i conect all my wires in my mainboard , mks gen l v1.0, is the firmware, problem ? I instaled the ender 3 configuration in marlin , from github , and modify that from standard , to setting for mks board
Logs (octoprint.log, serial.log or output on terminal tab, ...)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
octoprint version 1.3.11, octopi version 0.16.0, printer ender 3 pro , firmware marlin arduino version 1.8.9, here is my configuration CONDIGURATION_SIMPLE.zip (1.1 MB)
mainboard mks gen l v1.0, raspberry pi 3b+, tmc2208, touchscreen tft 28 inch
please check only my marlin firmware to see if it is good for mks gen l mainboard , and if it has no mistakes taht cause my printer doesn"t work propely , or the touchscreen
And a serial.log, which sounds like the more important factor here actually.
This is a forum for OctoPrint, not a free "check my firmware config" service. If you share your logs we can tell you what kind of issue you are facing, but it's your responsibility to solve it.
Also let me repeat my request for spell checking and proper punctuation...
I'm glad to see that you got OctoPrint working for your printer, that it's moving now, heating and printing. (Sometimes you just need to first home your X/Y and Z motors before your firmware wants to actually respond to the remaining move commands.)
As for adding a screen to your RAMPS board, that's a little outside of our area of expertise here. You might want to ask the vendor who sold you the TFT screen and see if they can help with that part. Good luck.
ok, i will try to contact him , i don't know if him can help me or he is just selling that touchscreen , i didn't home x/x z already beacouse i had my direction wrong, obly now i modifyed that firmware and change the direction, i don't know why i works now, i think first time i had my fans and motor off ,anyway tanks for your help!
HY , im back , i succeeded to install my tft scren, all was fine but the only problem was the baudrate , it was wrong so the screen couldn't comunicate with the board
I had this issue as well and my OctoPrint install was a few versions out of date. The only solution that worked for me was SSHing into the pi and doing a manual upgrade.
I was also having issues with OctoPrint not booting properly and I'd have to restart multiple times before it'd work.
I had the odd problem that Octoprint worked across the network and could ping Octoprint.org but failed the 8.8.8.8 port 53 test. and could not access the repository.
Finally traced to my extra lines tacked at the bottom of dhcpcd.conf to make the IP static
When setting the server's fixed IP I used router, not routers and static domain_name_server... You get the idea. After a reboot the connection was fine.
interface wlan0
static ip_address=192.168.1.118/24
static routers=192.168.1.1
static domain_name_servers=8.8.8 8
I hope this helps someone.
John
