I cant install plugins namely octoprint anywhere or spaghetti detective
cry
(Caused by SSLError(SSLError(1, u'[SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:727)'),))
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
What do I need to do to stop getting this error message when trying to install plugins?
Please help please thank you very much thank you
@Kenneth_Jiang might be able to weigh in here on this.
I saw this issue yesterday caused by the device being forcible powered off. We resolved it with a reinstall of OctoPi. I'll bring this to Kenneth's attention.
Things to note about the other person's issue is they were running OctoPi 0.15.0PE which I can't find any information on.
Actually looking further the OP is also getting the same issue with downloading updates for OctoLapse. Line number nine in the log
Thanks , I'm running 2019-09-26-octopi-buster-lite-0.17.0 . I've tried staring again from scratch twice on one pi and once on another, using the same image on both pis. model b3+
Searching for this turns up issues on the guysoft repository with older versions of OctoPrint. Maybe it's a Prusa fork...?
OctoPrint version : 1.3.10
OctoPi version : 0.15.0PE
