I followed official Download&Setup instruction. but, wifi did not connected.
among instruction, there is a phrase that i cant understand. that phrase is :
- Unzip the image and install the contained
.imgfile to an SD card [using Etcher]. Do not at any point format the SD from your Operating System, even if prompted to do so - that will break it and you’ll have to start over. Just use Etcher to flash the.imgfile, that is enough!
what is that means do not format? I formatted sd card with SD Card Formatter(windows 7) before burn img file via Etcher.
When instruction says do not format, is that means 'doesnt matter what kind of data in the sd card, just burn it'?
sd card that have history of format, cannot be used?
