I get Unexpected error while reading serial port
When clicking connect to the printer it shows as connected reads all the information and the files on the SD card then after 5 seconds I get "Unexpected error while reading serial port" and it disconnects. This happens every time I try to connect
The same thing happens if I try to connect while printing
Changed power supply, changed baud rates
Yes
No exactly the same
octoprint-systeminfo-20221013121917.zip (95.1 KB)
OctoPrint Version 1.8.4
OctoPi Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Board BIGTREETECH-SKR-V1.3
Marlin Version 2.1.1
Windows 10
Firefox
Hello @NickB355 !
Have you had a loon on this link?
Thank you for your reply, yes I have gone through all the items there, my problem is not random, it does it at the same point every time.
Have you tried it with a different SD card in the printer (or formatting the existing one, or without an SD card in)? Perhaps there is something wrong with the current one that is causing the printer to crash when it tries to list the files.
You must have read my mind, I have just tried it without the SD card in it and all seem good! I will try a different one. Thank you for your help
