I have a problem when sending file from Cura to Octopi. I got error:
file_name.ufp.gcode is not found on "local"
I must start printing manually.
This worked fine untill I installed PrintJobHistory plug in with all dependencies. I found out that it might be problem with UltimakerFormatPackage, but when I disable this one I got error that name_file.ufp is not supported untill I enable this plug in. My friend installed PrintJobHistory and do not have such a problem. How can I sole that error that it looks for file.ufp.gcode instead of filename.gcode?
