When I go to install a plugin (any plugin), I get this error message:
"Installing plugin "OctoEverywhere - Free Remote Access, AI Failure Detection, And More!" from https://github.com/QuinnDamerell/OctoPrint-OctoEverywhere/archive/master.zip...
Error!
Unexpected error while trying to install plugin from None"
In this case, I'm trying to install the OctoEverywhere plugin, but I get this message every time I try to install something. The PI is connected via ethernet to a wireless bridge router, but I wouldn't think the router is the issue as any time I connect my laptop to the router (Wifi, or ethernet), I'm able to access websites such as Amazon.
- Rebooting the PI and router
- Power cycling the PI and router
- Resetting the router
- Changing the routers IP
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1823.41
connectivity.connection_check : 192.168.0.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : cr-10-mini.local
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 900
env.hardware.ram : 912896000
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 2 Model B Rev 1.1
env.plugins.pi_support.octopi_version : 1.0.0
env.plugins.pi_support.octopiuptodate_build : 1.0.0-1.8.7-20230302160739
env.plugins.pi_support.throttle_check_enabled : true
env.plugins.pi_support.throttle_check_functional : true
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 22.3
env.python.version : 3.9.2
env.python.virtualenv : true
octoprint.last_safe_mode.date : 2023-05-29T03:17:27Z
octoprint.last_safe_mode.reason : incomplete_startup
octoprint.safe_mode : false
octoprint.version : 1.8.7
systeminfo.generated : 2023-06-07T02:15:37Z
systeminfo.generator : systemapi
octoprint-systeminfo-20230607031555.zip (4.6 KB)
Please let me know if more is needed here!
Main routers IP is "10.0.0.1"
Bridged routers IP is "192.168.0.1"
I access OctoPI with "cr-10-mini.local"
Raspberry PI: PI 2 Model B V1.1
Router: TP-Link AC1750
