MK1112 Shutdown error using Octoprint and Ortur Obsidian 3d Printer
So far increased time outs, Replaced USB Cable
Not yet.
N/A
Complete Logs
| Send: N25880 G1 X93.44 Y151.124 E372.2239398
| Recv: Not SD printing
| Recv: T:220.54 /220.00 B:58.39 /55.00 @:54 B@:0
| Recv: ok
| Send: N25881 G1 X93.435 Y151.028 E372.2263383
| Recv: ok
| Send: N25882 G1 X93.435 Y88.109 E373.79585102
| Recv: Error:No Checksum with line number, Last Line: 25880
| Recv: Resend: 25881
2021-01-30 13:41:40,183 - octoprint.util.comm - INFO - Ignoring resend request for line 25881, that still originates from lines we sent before we got the first resend request
2021-01-30 13:52:33,050 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-30 14:07:33,054 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-30 14:22:33,062 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-30 14:34:35,562 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-01-30 14:34:35,598 - octoprint.util.comm - WARNING - Printer requested line 1 but no sufficient history is available, can't resend. Printer requested line 1, current line is 33791, line history has 50 entries.
2021-01-30 14:34:35,602 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error: Printer requested line 1 but no sufficient history is available, can't resend"
2021-01-30 14:34:35,617 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2021-01-30 14:34:35,672 - octoprint.util.comm - INFO - Changing monitoring state from "Error: Printer requested line 1 but no sufficient history is available, can't resend" to "Offline (Error: Printer requested line 1 but no sufficient history is available, can't resend)"
2021-01-30 14:34:35,707 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 1, current line = 33794
| Last lines in terminal:
| Recv: Watchdog Reset
| Recv: Marlin RTOS 2.1.6
| Recv:
| Recv: echo: Last Updated: Nov 24 2020 | Author: (RenShen, ORTUR Obsidian config)
| Recv: echo:Compiled: Nov 24 2020
| Recv: echo: Free Memory: -10025 PlannerBufferBytes: 1344
| Recv: echo:V85 stored settings retrieved (770 bytes; crc 7645)
| Recv: X:-2.00 Y:-10.00 Z:0.12 E:0.00 Count X:-160 Y:-800 Z:2
| Recv: echo:SD card ok
| Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
| Send: N33790 M10541
| Recv: Error:Line Number is not Last Line Number+1, Last Line: 0
| Recv: Resend: 1
| Send: M112
| Send: N33791 M11246
| Send: N33792 M104 T0 S045
| Send: N33793 M140 S0*104
2021-01-30 14:34:35,717 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
2021-01-30 14:34:35,794 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-30 14:34:36,228 - octoprint.util.comm - INFO - Firmware didn't send an 'ok' with their resend request. That's a known bug with some firmware variants out there. Simulating an ok to continue...
2021-01-30 14:37:33,064 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-30 14:52:33,066 - octoprint.server.heartbeat - INFO - Server heartbeat <3
OctoPrint version: 1.5.3
OctoPi version: 0.17.0
Printer: Ortur Obsidian
Firmware: V62.20201018
Operating System: Marlin RTOS V62.20201018
Printer works fine If I use the SD card in it. But bc of this error I cannot use Octoprint.
