After updating for latest 15.2 I cannot connect to my printer - Tevo Tornado.
I formated the SD Card and did a new fresh install and I got the same result.
No safe mode was tested.
Complete Logs
I just updated to 1.5.2 and I'm not able to connect to the Printer
2021-01-22 10:31:11,218 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-22 10:31:11,336 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@19200
2021-01-22 10:31:11,340 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 19200
2021-01-22 10:31:11,346 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 19200
2021-01-22 10:31:11,590 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-01-22 10:31:11,724 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:31:13,807 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2021-01-22 10:31:13,873 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:31:14,344 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 25.84ms
2021-01-22 10:31:14,416 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 24.00ms
2021-01-22 10:31:15,880 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2021-01-22 10:31:15,906 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:31:15,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.97ms
2021-01-22 10:31:17,909 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-01-22 10:31:17,969 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 39.16ms
2021-01-22 10:31:18,064 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-01-22 10:31:18,082 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-22 10:31:19,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 30.36ms
2021-01-22 10:31:21,953 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.52ms
2021-01-22 10:31:23,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 33.26ms
2021-01-22 10:31:25,955 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.50ms
2021-01-22 10:31:27,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.52ms
2021-01-22 10:31:29,950 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.53ms
2021-01-22 10:31:31,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.61ms
2021-01-22 10:31:33,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.97ms
2021-01-22 10:31:35,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.60ms
2021-01-22 10:31:37,950 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.33ms
2021-01-22 10:31:39,955 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 30.95ms
2021-01-22 10:31:41,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.86ms
2021-01-22 10:31:43,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.19ms
2021-01-22 10:31:45,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.50ms
2021-01-22 10:31:47,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.46ms
2021-01-22 10:31:49,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.68ms
2021-01-22 10:31:51,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.93ms
2021-01-22 10:31:53,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.91ms
2021-01-22 10:31:55,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.54ms
2021-01-22 10:31:57,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.44ms
2021-01-22 10:31:59,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.71ms
2021-01-22 10:32:01,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.97ms
2021-01-22 10:32:03,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.88ms
2021-01-22 10:32:05,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 32.69ms
2021-01-22 10:32:07,972 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.63ms
2021-01-22 10:32:09,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.03ms
2021-01-22 10:32:11,966 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.84ms
2021-01-22 10:32:13,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.92ms
2021-01-22 10:32:15,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.67ms
2021-01-22 10:32:17,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 30.98ms
2021-01-22 10:32:19,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.30ms
2021-01-22 10:32:21,961 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.39ms
2021-01-22 10:32:23,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.11ms
2021-01-22 10:32:25,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.52ms
2021-01-22 10:32:27,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.93ms
2021-01-22 10:32:29,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.33ms
2021-01-22 10:32:31,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.06ms
2021-01-22 10:32:33,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.93ms
2021-01-22 10:32:35,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.69ms
2021-01-22 10:32:37,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.28ms
2021-01-22 10:32:39,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.82ms
2021-01-22 10:32:41,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.21ms
2021-01-22 10:32:43,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.13ms
2021-01-22 10:32:45,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.53ms
2021-01-22 10:32:47,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.14ms
2021-01-22 10:32:49,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.96ms
2021-01-22 10:32:51,948 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 21.03ms
2021-01-22 10:32:53,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.90ms
2021-01-22 10:32:55,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.74ms
2021-01-22 10:32:57,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.39ms
2021-01-22 10:32:59,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.45ms
2021-01-22 10:33:01,955 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.24ms
2021-01-22 10:33:03,331 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-22 10:33:03,417 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@19200
2021-01-22 10:33:03,420 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 19200
2021-01-22 10:33:03,424 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 19200
2021-01-22 10:33:03,466 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-01-22 10:33:03,473 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:33:06,347 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 21.33ms
2021-01-22 10:33:06,405 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 20.73ms
2021-01-22 10:33:06,616 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2021-01-22 10:33:06,635 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:33:07,953 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.50ms
2021-01-22 10:33:08,639 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2021-01-22 10:33:08,657 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-22 10:33:09,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.62ms
2021-01-22 10:33:11,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.40ms
2021-01-22 10:33:12,323 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-01-22 10:33:12,369 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-01-22 10:33:12,388 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-01-22 10:33:13,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.76ms
2021-01-22 10:33:15,965 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.83ms
2021-01-22 10:33:17,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.82ms
2021-01-22 10:33:19,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.82ms
2021-01-22 10:33:21,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.54ms
2021-01-22 10:33:23,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.42ms
2021-01-22 10:33:25,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.52ms
2021-01-22 10:33:27,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.23ms
2021-01-22 10:33:29,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.62ms
2021-01-22 10:33:31,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.81ms
2021-01-22 10:33:33,953 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.56ms
2021-01-22 10:33:35,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.42ms
2021-01-22 10:33:37,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.54ms
2021-01-22 10:33:39,955 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.28ms
2021-01-22 10:33:41,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.98ms
2021-01-22 10:33:43,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.92ms
2021-01-22 10:33:45,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.21ms
2021-01-22 10:33:47,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.51ms
2021-01-22 10:33:49,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.97ms
2021-01-22 10:33:51,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.32ms
2021-01-22 10:33:54,022 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.14ms
2021-01-22 10:33:55,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.70ms
2021-01-22 10:33:57,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.19ms
2021-01-22 10:33:59,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.42ms
2021-01-22 10:34:01,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.15ms
2021-01-22 10:34:03,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 32.33ms
2021-01-22 10:34:05,957 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.36ms
2021-01-22 10:34:07,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.39ms
2021-01-22 10:34:09,961 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.34ms
2021-01-22 10:34:11,953 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.09ms
2021-01-22 10:34:13,953 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.68ms
2021-01-22 10:34:15,963 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.77ms
2021-01-22 10:34:17,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.56ms
2021-01-22 10:34:19,951 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 21.23ms
2021-01-22 10:34:21,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.18ms
2021-01-22 10:34:23,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.81ms
2021-01-22 10:34:25,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.59ms
2021-01-22 10:34:27,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.83ms
2021-01-22 10:34:29,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.65ms
2021-01-22 10:34:31,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.59ms
2021-01-22 10:34:33,950 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 25.93ms
2021-01-22 10:34:35,963 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 30.71ms
2021-01-22 10:34:37,960 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.26ms
2021-01-22 10:34:39,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.79ms
2021-01-22 10:34:41,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.57ms
2021-01-22 10:34:43,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.21ms
2021-01-22 10:34:45,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.48ms
2021-01-22 10:34:47,954 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.11ms
2021-01-22 10:34:49,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 31.41ms
2021-01-22 10:34:51,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.18ms
2021-01-22 10:34:53,962 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.71ms
2021-01-22 10:34:55,958 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 27.63ms
2021-01-22 10:34:57,952 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.81ms
2021-01-22 10:34:59,956 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.90ms
2021-01-22 10:35:00,339 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-22 10:35:01,965 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.07ms
2021-01-22 10:35:03,959 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 28.75ms
2021-01-22 10:35:05,960 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.1.60) 29.25ms
2021-01-22 10:35:07,474 - octoprint.server.util.sockjs - INFO - Client connection closed: 2001:16a2:401e:c4ba:e00d:5699:91e2:1f21
