I upgraded today to 1.8.3. After printing started camera not working. Obico plugin not working.
After 30 min printing, octoprint disconnected. After that point the restart, shutdown not working.
With 1.8.2 everything working fine.
Disable resource monitor, but not solved my problem.
Im having similar problems, updated to 1.8.3 and now octoprint disconnects sometimes in 1h sometimes after 7h. 15h print yesterday worked when i had my usb camera unplugged
Resource monitor and Obico working with 1.8.2.
Is there a way to return back to 1.8.2?
Turning off all of my plug-ins is not an option for me.
What plug-in cause the disconnection?
"If you use UI customizer, you will not need Themeify."
There is something Themeify knows and UI customizer doesn't.
I could not remember any blobs on my prints. But for safety and as I usually don't watch resource monitor, I turned it off.
Today I updated Obico, and now camera is working again.
Maybe Obico plug-in caused the disconnection. I have to print more to check it.
With Themeify I can easily set exact height of each panel, like "Files", etc.
It is even worse. Now I have 1.8.4. I have to turn off UI Customizer because octoprint didn't start up just in safe mode. The first loading proccess is a pain. I have to wait for the camera picture to start.
not really seeing any specific errors in that log that would indicate why you would be having a problem with UI Customizer and I've been using 1.8.4 since prior to its official release with that plugin enabled. check your browser's developer tools > console tab to see what errors are lurking in there during initial page load.
