I have a prusa mk3s and a Raspberry Pi 3B+ with octoprint and a relay to turn off the printer by software. At the moment I have to manually set Serial Port to /dev/ttyACM0 and Baudrate to 115200 and click "connect", then go to prusaslicer and finally send to octoprint. I would like to skip the "connect" step: turn on the relay of the printer and it automatically connect to octoprint so I can use only prusaslicer to send the gcode and start the print.
The option "Auto-connect on server startup" is checked.
I installed the plugin "PortLister" but nothing changed.
Years ago I used Cura instead of prusaslicer and if I remember correctly there was a button to connect directly there. Maybe is there something like that on prusaslicer too?
OctoPrint version: 1.8.1, OctoPi version: 0.18.0, printer: prusa mk3s, firmware: 3.10.0-4481, browser: chrome, operating system: windows
Thank you
