I connected to PuTTY and typed: systemctl status octoprint
pi@octopi:~ systemctl status octoprint
β octoprint.service - The snappy web interface for your 3D printer
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset
Active: failed (Result: exit-code) since Wed 2021-10-13 15:29:35 EDT; 3min 36
Process: 1138 ExecStart=/home/pi/oprint/bin/octoprint serve --host={HOST} --p
Main PID: 1138 (code=exited, status=1/FAILURE)
Oct 13 15:29:35 octopi systemd[1]: Started The snappy web interface for your 3D
Oct 13 15:29:35 octopi octoprint[1138]: Traceback (most recent call last):
Oct 13 15:29:35 octopi octoprint[1138]: File "/home/pi/oprint/bin/octoprint",
Oct 13 15:29:35 octopi octoprint[1138]: from octoprint import main
Oct 13 15:29:35 octopi octoprint[1138]: ModuleNotFoundError: No module named 'oc
Oct 13 15:29:35 octopi systemd[1]: octoprint.service: Main process exited, code=
Oct 13 15:29:35 octopi systemd[1]: octoprint.service: Failed with result 'exit-c
...skipping...
Process: 1138 ExecStart=/home/pi/oprint/bin/octoprint serve --host=${HOST} --p
lines 1-13/13 (END)
Not sure where to go from here
