If resolution changed camera does not function propery
i have a gopro hero4 through hdmit - csi2
when i plug it in and turn on octoprint everything is fine, but if i go into boot.txt and change the resolution area to 1920x1080 it changes the resolution but make the image bad, im not sure what it is called. kind of reminds me of water color painting.
fresh install. changed setting per directions.
not sure how to get logs for this
You have to change the camera resolution in the octopi.txt - where did you find a boot.txt?
Check out this guide
Also make sure to limit the fps to 25 or less. Afaik those hdmi to csi boards don't support higher framerates.
