I currently have Octoprint version 1.3.12 and I'm trying to install the update for version 1.4 but with the update manager inside the service it results in an Error.
I tried solving it by updating manually by doing the command inside the virtual environment with 'pip install -U octoprint' but it results in the samen error
UI Error message:
ERROR: Command errored out with exit status 1: /home/santiago/share/Octoprint/env/bin/python2 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-EUFIia/psutil/setup.py'"'"'; __file__='"'"'/tmp/pip-install-EUFIia/psutil/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ajmR0g/install-record.txt --single-version-externally-managed --compile --install-headers /home/santiago/share/Octoprint/env/include/site/python2.7/psutil
Check the logs for full command output.
Log:
octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
File "/home/santiago/share/Octoprint/env/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 987, in _perform_update
update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
File "/home/santiago/share/Octoprint/env/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
Im running octoprint in ubuntu server 18.04
Thank you for any information about how can i solve this
