To start with I resolved the issue but I want to know what caused it.
I re-imaged my Octoprint server to the latest stable build (1.7.3 and 0.18)
I used the Raspberry Pi Imager to install. When I completed the image and
manually updated the network supplicant file with the correct network settings
I put the micro sd in the raspberry pi and Octoprint did not come up.
I then used a terminal to access the pi and discovered that the OctoPrint
folder had only a blank readme.txt file. The initial screen indicated I had 0.18 but the OctoPrint did not
seem to be there. I manually ran
~/oprint/bin/pip install --force-reinstall OctoPrint==1.7.3 --no-cache-dir
which once completed OctoPrint now comes up correctly.
I tried this again with another micro sd card and noticed that the settings
for country code was set to "GB" so I modified it to be "US" This time the installation
worked correctly and OctoPrint came up fine.
What could have happened with the first failure? There was only a single empty reademe.txt file present in the
OctoPrint folder. The micro sd cards were the same brand and size.
Reinstalled Octoprint manually via a terminal.
