IMX519
OV5647 (Working)
Camera will not show up. Other cameras work so I know its not the hardware.
Factory reset the PI. Installtion instructions from here.
pi@raspberrypi:~ $ vcgencmd get_camera
supported=1 detected=0
So it supports the webcam but cannot detect it. I have bought 2 of these cameras thinking it may have been a faulty one.
Logs kept saying pi@raspberrypi:~ $ sudo: /var/log/webcamd.log: command not found
-bash: sudo:: command not found
pi@raspberrypi:~ $ journalctl -u webcamd
-- Logs begin at Mon 2022-06-20 12:17:02 EDT, end at Mon 2022-06-20 13:39:35 EDT
Jun 20 13:30:22 raspberrypi systemd[1]: Starting the OctoPi webcam daemon with t
Jun 20 13:38:18 raspberrypi systemd[1]: webcamd.service: Start operation timed o
Jun 20 13:38:18 raspberrypi systemd[1]: webcamd.service: Failed with result 'tim
Jun 20 13:38:18 raspberrypi systemd[1]: Failed to start the OctoPi webcam daemon
Jun 20 13:38:19 raspberrypi systemd[1]: webcamd.service: Service RestartSec=1s e
Jun 20 13:38:19 raspberrypi systemd[1]: webcamd.service: Scheduled restart job,
Jun 20 13:38:19 raspberrypi systemd[1]: Stopped the OctoPi webcam daemon with th
Jun 20 13:38:19 raspberrypi systemd[1]: Starting the OctoPi webcam daemon with t
lines 1-9/9 (END)...skipping...
-- Logs begin at Mon 2022-06-20 12:17:02 EDT, end at Mon 2022-06-20 13:39:35 EDT. --
Jun 20 13:30:22 raspberrypi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 20 13:38:18 raspberrypi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Jun 20 13:38:18 raspberrypi systemd[1]: webcamd.service: Failed with result 'timeout'.
Jun 20 13:38:18 raspberrypi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified con
Jun 20 13:38:19 raspberrypi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Jun 20 13:38:19 raspberrypi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Jun 20 13:38:19 raspberrypi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Jun 20 13:38:19 raspberrypi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 20 13:38:18 raspberrypi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
lines 1-9/9 (END)
Rasberry Pi 4 - Ender 3
