I have Octoprint 1.5.1 installed and working fine on RPI4b on Ender 3 V2 with Smith 4x4 + filament sensor. All works fine.
When i use Control I can watch the printing perfectly.
when i try to access time lapse pictures there is nothing there
in settings the snapshot url is set as "http://192.168.1.142/8080/?action=snapshot"
and pressing the test button the error could not retrieve snapshot URL.
Path to FFMPEG set to "/usr/bin/ffmpeg" and tests fine.
tried various url s for snapshot with no difference
Yes and no different
Complete Logs
