Cannot update
Looked at logs like it asked me to do
not yet
Complete Logs
2020-12-09 21:01:09,894 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-12-09 21:01:09,897 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-12-09 21:01:09,898 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-12-09 21:01:09,900 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-12-09 21:01:10,865 - octoprint.startup - INFO - Blacklist processing done, adding 10 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8)
2020-12-09 21:01:10,977 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-12-09 21:01:12,748 - octoprint.plugin.core - INFO - Plugin Virtual Printer is disabled.
2020-12-09 21:01:14,814 - octoprint.plugin.core - INFO - Plugin Slicer (1.4.3) is disabled.
2020-12-09 21:01:15,165 - octoprint.plugin.core - INFO - Plugin Filament Sensor Reloaded (1.3.4) is disabled.
2020-12-09 21:01:15,295 - octoprint.plugin.core - INFO - Plugin OctoEverywhere! (0.4.0) is disabled.
2020-12-09 21:01:15,677 - octoprint.plugin.core - INFO - Found 34 plugin(s) providing 30 mixin implementations, 49 hook handlers
2020-12-09 21:01:16,101 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-12-09 21:01:16,180 - octoprint.server - INFO - Intermediary server started
2020-12-09 21:01:16,264 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-12-09 21:01:17,268 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-12-09 21:01:17,278 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-12-09 21:01:17,280 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-12-09 21:01:17,283 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-12-09 21:01:17,286 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-12-09 21:01:17,288 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-12-09 21:01:17,292 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-12-09 21:01:17,296 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-12-09 21:01:17,299 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-12-09 21:01:17,303 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-12-09 21:01:17,305 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-12-09 21:01:17,309 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-09 21:01:17,312 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-09 21:01:17,316 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-12-09 21:01:17,319 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-12-09 21:01:17,321 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2020-12-09 21:01:18,480 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-12-09 21:01:21,162 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-09 21:01:23,505 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-12-09 21:01:23,509 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-09 21:01:23,510 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-09 21:01:23,526 - octoprint.plugin.core - INFO - Initialized 30 plugin implementation(s)
2020-12-09 21:01:23,611 - octoprint.plugin.core - INFO - 34 plugin(s) registered with the system:
| Access Anywhere - The Spaghetti Detective (1.4.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_thespaghettidetective
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Backup Scheduler (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_backupscheduler
| Change Filament Plugin (0.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_Change_Filament
| Cost Estimation (3.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_costestimation
| Detailed Progress (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_detailedprogress
| DisplayProgress (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_displayprogress
| !Filament Sensor Reloaded (1.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentreload
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| FileManager (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| Firmware Updater (1.7.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| Fullscreen Plugin (0.0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| !OctoEverywhere! (0.4.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octoeverywhere
| Resource Monitor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_resource_monitor
| Simple Emergency Stop (1.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_simpleemergencystop
| !Slicer (1.4.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_slicer
| Title Status (0.0.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_title_status
| !Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
| Webcam Tab (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_webcamtab
| YouTube Live (0.5.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_youtubelive
2020-12-09 21:01:23,662 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
2020-12-09 21:01:23,692 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| throttle_state: '0x50005'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-12-09 21:01:23,726 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-12-09 21:01:23,777 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-12-09 21:01:35,516 - octoprint.server - INFO - Shutting down intermediary server...
2020-12-09 21:01:35,944 - octoprint.server - INFO - Intermediary server shut down
2020-12-09 21:01:35,950 - octoprint.events - INFO - Processing startup event, this is our first event
2020-12-09 21:01:35,951 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2020-12-09 21:01:35,961 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-12-09 21:01:35,963 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-12-09 21:01:36,064 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-12-09 21:01:36,093 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-12-09 21:01:36,490 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-09 21:01:40,575 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-09 21:01:40,618 - octoprint.server - INFO - Trying to connect to configured serial port AUTO
2020-12-09 21:01:40,783 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-12-09 21:01:41,033 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-12-09 21:01:41,048 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-12-09 21:01:41,200 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@250000
2020-12-09 21:01:41,202 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2020-12-09 21:01:41,204 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 250000
2020-12-09 21:01:41,223 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2020-12-09 21:01:41,234 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-09 21:01:41,931 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2020-12-09 21:01:42,157 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-12-09 21:01:42,323 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-09 21:01:42,341 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2020-12-09 21:01:42,344 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2020-12-09 21:01:42,787 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2020-12-09 21:01:42,803 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-12-09 21:01:42,810 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-12-09 21:01:43,306 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-09 21:01:45,880 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-09 21:01:46,084 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-09 21:01:46,113 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-09 21:01:46,288 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 4.8GB. That is considered sufficient for updating.
2020-12-09 21:01:47,354 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-09 21:01:47,363 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.0-RC8 (Github)"
2020-12-09 21:01:47,707 - octoprint.plugins.detailedprogress - INFO - OctoPrint-DetailedProgress loaded!
2020-12-09 21:01:47,723 - octoprint.plugins.youtubelive - INFO - OctoPrint-YouTubeLive loaded! Checking stream status.
2020-12-09 21:01:47,794 - octoprint.plugins.youtubelive - ERROR - ('Connection aborted.', error(2, 'No such file or directory'))
2020-12-09 21:01:48,711 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-12-09 21:01:49,298 - octoprint.plugins.thespaghettidetective - INFO - User account: {u'is_pro': False}
2020-12-09 21:02:20,721 - octoprint.server.preemptive_cache - INFO - ... done in 32.01s
2020-12-09 21:04:26,849 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.48
2020-12-09 21:04:27,080 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.48
2020-12-09 21:04:27,084 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:04:27,189 - octoprint.server.util.sockjs - INFO - User admin logged in on the socket from client ::ffff:192.168.0.48
2020-12-09 21:04:31,315 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.48
2020-12-09 21:04:31,479 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.48
2020-12-09 21:04:31,483 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:04:31,715 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.48
2020-12-09 21:04:31,719 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:04:31,775 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.48
2020-12-09 21:04:31,840 - octoprint.server.util.sockjs - INFO - User admin logged in on the socket from client ::ffff:192.168.0.48
2020-12-09 21:04:36,217 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.48
2020-12-09 21:04:36,283 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.48
2020-12-09 21:04:36,287 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:04:40,926 - octoprint.plugins.youtubelive - INFO - Checking stream status.
2020-12-09 21:04:45,760 - octoprint.server.util.sockjs - INFO - User admin logged in on the socket from client ::ffff:192.168.0.48
2020-12-09 21:07:38,540 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.24
2020-12-09 21:07:51,838 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:07:51,844 - octoprint.server.api - INFO - Actively logging in user admin from ::ffff:192.168.0.24
2020-12-09 21:07:51,995 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.24
2020-12-09 21:07:51,999 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:07:52,476 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.24
2020-12-09 21:07:54,751 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.24
2020-12-09 21:07:54,837 - octoprint.server.util.flask - INFO - Passively logging in user admin from ::ffff:192.168.0.24
2020-12-09 21:07:54,839 - octoprint.access.users - INFO - Logged in user: admin
2020-12-09 21:07:58,853 - octoprint.plugins.youtubelive - INFO - Checking stream status.
2020-12-09 21:08:03,353 - octoprint.server.util.sockjs - INFO - User admin logged in on the socket from client ::ffff:192.168.0.24
2020-12-09 21:09:09,451 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.48
2020-12-09 21:10:22,948 - tornado.access - WARNING - 409 POST /plugin/softwareupdate/update (::ffff:192.168.0.24) 34.09ms
2020-12-09 21:10:29,120 - tornado.access - WARNING - 409 POST /plugin/softwareupdate/update (::ffff:192.168.0.24) 31.61ms
2020-12-09 21:10:34,751 - tornado.access - WARNING - 409 POST /plugin/softwareupdate/update (::ffff:192.168.0.24) 31.59ms
2020-12-09 21:10:40,015 - tornado.access - WARNING - 409 POST /plugin/softwareupdate/update (::ffff:192.168.0.24) 30.12ms
2020-12-09 21:16:16,108 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-09 21:17:05,864 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 4.8GB. That is considered sufficient for updating.
2020-12-09 21:17:15,450 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-09 21:17:15,455 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-09 21:17:15,457 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-09 21:17:15,941 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-12-09 21:26:15,253 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-12-09 21:26:19,920 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-12-09 21:26:35,855 - tornado.access - WARNING - 409 POST /plugin/softwareupdate/update (::ffff:192.168.0.24) 52.66ms
anycubic mega s, Used
1.8 GB (27%)
Free
4.9 GB
Total
7 GB
Mountpoint
Device
/dev/root
Type
ext4
- OctoPrint 1.5.0
- Python 2.7.16
- OctoPi 0.17.
