Initial install problems Zero 2 W
Octoprint does not load. I get The OctoPrint server is currently not running
  • Verify that the process is running: ps -ef | grep -i octoprint | grep -i python should show a python process:
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
I searched through what I could on here.
I have tried reflashing image, manually downloading image, restarting, updating via | oprint/bin/pip install -U octoprint | which says [notice] A new release of pip is available: 25.0.1 -> 25.3
[notice] To update, run: python -m pip install --upgrade pip
Then it says pi@HammyPi:~ $ python -m pip install --upgrade pip
error: externally-managed-environment
Γ— This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Tried updating with ~/oprint/bin/pip install --force-reinstall OctoPrint==x.x.x --no-cache-dir
other commands to restart state illegal instruction.
sudo systemctl status octoprint.service says
Γ— octoprint.service - The snappy web interface for your 3D printer
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; preset: enabled)
Active: failed (Result: signal) since Tue 2024-11-19 08:44:00 EST; 1 year 0 months ago
Duration: 32.893s
Main PID: 296 (code=killed, signal=ILL)
CPU: 3.612s
Nov 19 08:43:27 HammyPi systemd[1]: Started octoprint.service - The snappy web interface for your 3D printer.
Nov 19 08:44:00 HammyPi systemd[1]: octoprint.service: Main process exited, code=killed, status=4/ILL
Nov 19 08:44:00 HammyPi systemd[1]: octoprint.service: Failed with result 'signal'.
Nov 19 08:44:00 HammyPi systemd[1]: octoprint.service: Consumed 3.612s CPU time.
illegal instruction
no
I am trying to convert an ender 3 s1 to a wireless machine and potentially run klipper. I picked up a raspberry pi zero 2 w from the ZON and have been having "Fun" ever since.
Try these commands in SSH.
source ~/oprint/bin/activate
pip install pydantic_core==2.41.4
pip install --force-reinstall --no-cache-dir octoprint
octoprint serve
and report back any errors/messages that you get along the way. there have been a couple of reports from users on Discord related to zero 2 W and gen 1 pi b+ that had similar errors. haven't nailed down a complete solution yet.
source /oprint/bin/activate
-bash: /oprint/bin/activate: No such file or directory
pi@HammyPi:~ $ pip install pydantic_core==2.41.4
install.
Same externally managed error
pi@HammyPi:~ $ octoprint serve
-bash: octoprint: command not found
~ $ df -h
Filesystem Size Used Avail Use% Mounted on
udev 49M 0 49M 0% /dev
tmpfs 37M 992K 36M 3% /run
/dev/mmcblk0p2 29G 5.7G 22G 21% /
tmpfs 183M 0 183M 0% /dev/shm
tmpfs 5.0M 8.0K 5.0M 1% /run/lock
/dev/mmcblk0p1 510M 96M 415M 19% /boot/firmware
tmpfs 37M 0 37M 0% /run/user/1000
Apologies, missed a character in the first command. Edited above, try with the updated comment.
We have some movement, it looks like its downloading pydantic cores now
