I cannot acquire a local ip address after install of 0.15.1 on a new microSD card.
I recently replaced my pi cam with a Logitech C920. The added weight of the cable made my raspberry pi 3 enclosure topple over constantly. I powered down and moved the pi to its stock enclosure. It would not power up afterwards. I powered down, removed the microsd card only to find that Windows 7 would not read the card.
- I replaced the card since it was unreadable; can't format either, gives error.
- Formatted the new card to FAT (default choice)
- Flashed to the latest version of Octopi
- Followed the instructions to update the network file but realized this is a mistake because I am trying to setup as an ethernet connection. I then changed the file back to default and saved.
- After powering up with microsd card back in pi, I then checked Angry ip scanner and Fing. The new device does not show up. I can see the blinking green light, constant red light, and the lights of the ethernet outlet are all blinking so technically the device is working.
- I try Octopi.local- I get a timed out screen. I assume this is because it's trying to reach the old ip.
- I try to ping octopi.local. Response is there's no pi.
- I log into my ISP router, I see the device has ipv4 and ipv6 addresses.
- In the ISP router I also input the ipv4 and ipv6 addresses to the port forwarding entry.
- I reset all devices but nothing changed.
- I decided to try and input my ipv4 address into my web browser.
- Octoprint boots right up, so I start the setup process.
- I decide to reset instead of a completing the setup.
Still can't find the local ip. I am assuming I need the local ip before I can start the SSH portion of the setup. I'm also wondering if it's possible to just reformat the microsd and start over.
Octopi Version- 0.15.1 (attempting)
OctoPi version- N/A
Printer- Prusa i3 MK2S
Raspberry Pi- Raspberry Pi 3 v1.2
OS- Windows 7
Method- ethernet (as was previous setup)
MicroSD card- 16GB Sandisk (previous failed was Transcend 16GB)
