Installed plugin not showing
i installed OctoPrint-PiNozCam but its nowhere to be found in plugins I've checked the pi its there but cannot remove it as its not in plugins
any help would be great.
octoprint-systeminfo-20240927203709.zip (138.0 KB)
octoprint installed on pi 4 using octoprint deploy,
Providing the systeminfo bundle would be great too.
sorry i forgot
Seems to be the sae issua as it was sloved here:
thanks unfortunately it didn't work,
maybe as i used octoprint deploy to install my octoprint.
thanks
martin
yeah, the commands posted as solution would require some tweaking to activate the correct venv, the path is not the same as a default OctoPi image. Try these. If you get an error on the first command or the command line doesn't change and start with (venv), don't continue the next command.
source /home/pi/OctoPrint/bin/activate
pip install "numpy>=1.24.3,<1.26"
pip install pillow
pip install "onnxruntime @ https://github.com/nknytk/built-onnxruntime-for-raspberrypi-linux/raw/master/wheels/bullseye/onnxruntime-1.15.0-cp39-cp39-linux_armv7l.whl"
hi i tried that and it didn't come up with any errors at all so i re tried installing the plugin and got .
and
Installing plugin "OctoPrint-PiNozCam" from https://github.com/DrAlexLiu/OctoPrint-PiNozCam/archive/master.zip...
/home/pi/OctoPrint/bin/python3 -m pip --disable-pip-version-check install file:///tmp/tmpj8d98ji8/OctoPrint-PiNozCam-master.zip --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Processing /tmp/tmpj8d98ji8/OctoPrint-PiNozCam-master.zip
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl (from OctoPrint-PiNozCam==1.0.3)
Downloading https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl (6.9 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 6.9/6.9 MB 10.5 MB/s eta 0:00:00
Requirement already satisfied: OctoPrint in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint-PiNozCam==1.0.3) (1.10.2)
Requirement already satisfied: numpy<1.26,>=1.21.4 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint-PiNozCam==1.0.3) (1.25.2)
Requirement already satisfied: pillow in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint-PiNozCam==1.0.3) (10.0.1)
Requirement already satisfied: pyTelegramBotAPI in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint-PiNozCam==1.0.3) (4.23.0)
Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2024.3.27)
Requirement already satisfied: OctoPrint-FirmwareCheck>=2021.10.11 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2021.10.11)
Requirement already satisfied: OctoPrint-PiSupport>=2023.10.10 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2023.10.10)
Requirement already satisfied: argon2-cffi>=23.1.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (23.1.0)
Requirement already satisfied: Babel<2.13,>=2.12.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.12.1)
Requirement already satisfied: cachelib<0.11,>=0.10.2 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.10.2)
Requirement already satisfied: Click<9,>=8.1.7 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (8.1.7)
Requirement already satisfied: colorlog<7,>=6.7.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.7.0)
Requirement already satisfied: emoji<3,>=2.10.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.11.1)
Requirement already satisfied: feedparser<7,>=6.0.11 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.0.11)
Requirement already satisfied: filetype<2,>=1.2.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.2.0)
Requirement already satisfied: Flask-Assets<3,>=2.1.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.1.0)
Requirement already satisfied: Flask-Babel<4,>=3.1.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.1.0)
Requirement already satisfied: Flask-Login<0.7,>=0.6.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.6.3)
Requirement already satisfied: Flask-Limiter<4,>=3.5.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.5.0)
Requirement already satisfied: flask<2.3,>=2.2.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.2.5)
Requirement already satisfied: frozendict<3,>=2.4.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.4.2)
Requirement already satisfied: future<1,>=0.18.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.18.3)
Requirement already satisfied: markdown<3.5,>=3.4.4 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.4.4)
Requirement already satisfied: netaddr<0.9,>=0.8 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.8.0)
Requirement already satisfied: netifaces<0.12,>=0.11.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.11.0)
Requirement already satisfied: passlib<2,>=1.7.4 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.7.4)
Requirement already satisfied: pathvalidate<3,>=2.5.2 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.5.2)
Requirement already satisfied: pkginfo<2,>=1.9.6 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.9.6)
Requirement already satisfied: psutil<6,>=5.9.8 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (5.9.8)
Requirement already satisfied: pydantic==1.10.16 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.10.16)
Requirement already satisfied: pylru<2,>=1.2.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.2.1)
Requirement already satisfied: pyserial<4,>=3.5 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.5)
Requirement already satisfied: pytz in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2023.3.post1)
Requirement already satisfied: PyYAML<7,>=6.0.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.0.1)
Requirement already satisfied: requests<3,>=2.31.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.31.0)
Requirement already satisfied: sarge==0.1.7.post1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.1.7.post1)
Requirement already satisfied: semantic-version<3,>=2.10.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.10.0)
Requirement already satisfied: sentry-sdk<2,>=1.40.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.45.0)
Requirement already satisfied: setuptools in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (44.1.1)
Requirement already satisfied: tornado<6.3,>=6.2 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.2)
Requirement already satisfied: watchdog<3,>=2.3.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.3.1)
Requirement already satisfied: websocket-client==1.6.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.6.1)
Requirement already satisfied: werkzeug<2.3,>=2.2.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.2.3)
Requirement already satisfied: wrapt<1.16,>=1.15 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.15.0)
Requirement already satisfied: zeroconf~=0.127 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.132.2)
Requirement already satisfied: zipstream-ng<2.0.0,>=1.7.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.7.1)
Requirement already satisfied: blinker<1.7.0,>=1.6.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.6.3)
Requirement already satisfied: class-doc<0.3,>=0.2.6 in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.2.6)
Requirement already satisfied: regex in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (2023.8.8)
Requirement already satisfied: unidecode in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.3.6)
Requirement already satisfied: wheel in /home/pi/OctoPrint/lib/python3.9/site-packages (from OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.41.2)
Requirement already satisfied: typing-extensions>=4.2.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from pydantic==1.10.16->OctoPrint->OctoPrint-PiNozCam==1.0.3) (4.8.0)
Requirement already satisfied: coloredlogs in /home/pi/OctoPrint/lib/python3.9/site-packages (from onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (15.0.1)
Requirement already satisfied: flatbuffers in /home/pi/OctoPrint/lib/python3.9/site-packages (from onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (20181003210633)
Requirement already satisfied: packaging in /home/pi/OctoPrint/lib/python3.9/site-packages (from onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (23.1)
Requirement already satisfied: protobuf in /home/pi/OctoPrint/lib/python3.9/site-packages (from onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (5.28.2)
Requirement already satisfied: sympy in /home/pi/OctoPrint/lib/python3.9/site-packages (from onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (1.13.3)
Requirement already satisfied: argon2-cffi-bindings in /home/pi/OctoPrint/lib/python3.9/site-packages (from argon2-cffi>=23.1.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (21.2.0)
Requirement already satisfied: more-itertools>=5.0.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from class-doc<0.3,>=0.2.6->OctoPrint->OctoPrint-PiNozCam==1.0.3) (10.1.0)
Requirement already satisfied: sgmllib3k in /home/pi/OctoPrint/lib/python3.9/site-packages (from feedparser<7,>=6.0.11->OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.0.0)
Requirement already satisfied: Jinja2>=3.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from flask<2.3,>=2.2.3->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.1.2)
Requirement already satisfied: itsdangerous>=2.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from flask<2.3,>=2.2.3->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.1.2)
Requirement already satisfied: importlib-metadata>=3.6.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from flask<2.3,>=2.2.3->OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.8.0)
Requirement already satisfied: webassets>=2.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from Flask-Assets<3,>=2.1.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.0)
Requirement already satisfied: limits>=2.8 in /home/pi/OctoPrint/lib/python3.9/site-packages (from Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.6.0)
Requirement already satisfied: ordered-set<5,>4 in /home/pi/OctoPrint/lib/python3.9/site-packages (from Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (4.1.0)
Requirement already satisfied: rich<14,>=12 in /home/pi/OctoPrint/lib/python3.9/site-packages (from Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (13.5.3)
Requirement already satisfied: charset-normalizer<4,>=2 in /home/pi/OctoPrint/lib/python3.9/site-packages (from requests<3,>=2.31.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.2.0)
Requirement already satisfied: idna<4,>=2.5 in /home/pi/OctoPrint/lib/python3.9/site-packages (from requests<3,>=2.31.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.4)
Requirement already satisfied: urllib3<3,>=1.21.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from requests<3,>=2.31.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.26.20)
Requirement already satisfied: certifi>=2017.4.17 in /home/pi/OctoPrint/lib/python3.9/site-packages (from requests<3,>=2.31.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2024.8.30)
Requirement already satisfied: MarkupSafe>=2.1.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from werkzeug<2.3,>=2.2.3->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.1.3)
Requirement already satisfied: async-timeout>=3.0.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from zeroconf~=0.127->OctoPrint->OctoPrint-PiNozCam==1.0.3) (4.0.3)
Requirement already satisfied: ifaddr>=0.1.7 in /home/pi/OctoPrint/lib/python3.9/site-packages (from zeroconf~=0.127->OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.2.0)
Requirement already satisfied: humanfriendly>=9.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from coloredlogs->onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (10.0)
Requirement already satisfied: mpmath<1.4,>=1.1.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from sympy->onnxruntime@ https://github.com/DrAlexLiu/built-onnxruntime-for-raspberrypi-linux/raw/main/wheels/bullseye/onnxruntime-1.17.1-cp39-cp39-linux_armv7l.whl->OctoPrint-PiNozCam==1.0.3) (1.3.0)
Requirement already satisfied: zipp>=0.5 in /home/pi/OctoPrint/lib/python3.9/site-packages (from importlib-metadata>=3.6.0->flask<2.3,>=2.2.3->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.17.0)
Requirement already satisfied: deprecated>=1.2 in /home/pi/OctoPrint/lib/python3.9/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.2.14)
Requirement already satisfied: importlib-resources>=1.3 in /home/pi/OctoPrint/lib/python3.9/site-packages (from limits>=2.8->Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (6.1.0)
Requirement already satisfied: markdown-it-py>=2.2.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from rich<14,>=12->Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (3.0.0)
Requirement already satisfied: pygments<3.0.0,>=2.13.0 in /home/pi/OctoPrint/lib/python3.9/site-packages (from rich<14,>=12->Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.16.1)
Requirement already satisfied: cffi>=1.0.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from argon2-cffi-bindings->argon2-cffi>=23.1.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (1.15.1)
Requirement already satisfied: pycparser in /home/pi/OctoPrint/lib/python3.9/site-packages (from cffi>=1.0.1->argon2-cffi-bindings->argon2-cffi>=23.1.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (2.21)
Requirement already satisfied: mdurl~=0.1 in /home/pi/OctoPrint/lib/python3.9/site-packages (from markdown-it-py>=2.2.0->rich<14,>=12->Flask-Limiter<4,>=3.5.0->OctoPrint->OctoPrint-PiNozCam==1.0.3) (0.1.2)
Building wheels for collected packages: OctoPrint-PiNozCam
Building wheel for OctoPrint-PiNozCam (setup.py): started
Building wheel for OctoPrint-PiNozCam (setup.py): finished with status 'done'
Created wheel for OctoPrint-PiNozCam: filename=OctoPrint_PiNozCam-1.0.3-py2.py3-none-any.whl size=28211198 sha256=9d4668c112ea6e0bf8e728c4f7afbaa250d99999013f6b1de33d18e81eafb469
Stored in directory: /tmp/pip-ephem-wheel-cache-nuhkw0nu/wheels/f0/78/30/4dc9e79035fc5063ceb3e5d6b05d6bb6a6df14903f5ffc6f65
Successfully built OctoPrint-PiNozCam
Installing collected packages: onnxruntime, OctoPrint-PiNozCam
Attempting uninstall: onnxruntime
Found existing installation: onnxruntime 1.15.0
Uninstalling onnxruntime-1.15.0:
Successfully uninstalled onnxruntime-1.15.0
Attempting uninstall: OctoPrint-PiNozCam
Found existing installation: OctoPrint-PiNozCam 1.0.3
Uninstalling OctoPrint-PiNozCam-1.0.3:
Successfully uninstalled OctoPrint-PiNozCam-1.0.3
Successfully installed OctoPrint-PiNozCam-1.0.3 onnxruntime-1.17.1
Done!
still not showing in plugins
thanks
martin
