When restarting after system shutdown, I'm typically unable to start the server on power up. I say "typically" because occasionally I'm able to start without issue.
I have tried manually stopping and starting over ssh without any success (see logs below).
Tried starting in safe mode without success.
I've tried power cycling the pi, and sometimes I'm able to startup successfully (obviously not the ideal solution).
What DOES work is activating the virtual environment: source ~/oprint/bin/activate and starting OctoPrint manually on the console: octoprint serve --debug --host 127.0.0.1. Hopefully this offers some hints as to what is not configured properly.
No success starting in safe mode.
Complete Logs
None of the logs in .octoprint/logs contain any information since the last shutdown. There is no logging from the attempted startup.
When starting manually after activating the virtual environment I do not see any errors in the debug log.
I have the following output when trying to start manually:
pi@octopi:~ $ sudo service octoprint stop
pi@octopi:~ $ sudo service octoprint start
Job for octoprint.service failed because the control process exited with error code.
See "systemctl status octoprint.service" and "journalctl -xe" for details.
pi@octopi:~ $ systemctl status octoprint.service
β octoprint.service
Loaded: loaded (/etc/init.d/octoprint; generated)
Active: failed (Result: exit-code) since Sat 2020-10-17 19:33:58 EDT; 6s ago
Docs: man:systemd-sysv-generator(8)
Process: 678 ExecStart=/etc/init.d/octoprint start (code=exited, status=203/EXEC)
Oct 17 19:33:58 octopi systemd[1]: Starting octoprint.service...
Oct 17 19:33:58 octopi systemd[678]: octoprint.service: Failed to execute command: Exec format error
Oct 17 19:33:58 octopi systemd[678]: octoprint.service: Failed at step EXEC spawning /etc/init.d/octoprint: Exec format error
Oct 17 19:33:58 octopi systemd[1]: octoprint.service: Control process exited, code=exited, status=203/EXEC
Oct 17 19:33:58 octopi systemd[1]: octoprint.service: Failed with result 'exit-code'.
Oct 17 19:33:58 octopi systemd[1]: Failed to start octoprint.service.
OctoPrint v1.4.2
OctoPi v0.17.0
RPI 4B 4GB
Please let me know if any additional info would be helpful.
Thanks all for your help!
