Started getting 505 Internal Server Error when connecting to Octopi.
Everything was fine a week ago and I still have prints on the bed I haven't had time to remove yet.
Tried looking through the logs but can't work out the root cause of the error. Errors show up but are all Greek to me.
Tried SSH and restarting the server but get the same result.
Yes, exactly the same result
Nope
Complete Logs
2021-03-19 10:43:43,061 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-03-19 10:43:43,080 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2021-03-19 10:43:43,081 - octoprint.server - INFO - OctoPrint 1.5.2
2021-03-19 10:43:43,085 - octoprint.plugin.core - INFO - 30 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| !Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
| Autologin Configuration (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_autologin_config
| Bed Visualizer (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| !CANVAS (2.3.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_canvas
| Dashboard (1.17.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_dashboard
| Detailed Progress (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_detailedprogress
| Display ETA (1.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eta
| DisplayLayerProgress Plugin (1.24.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| !Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| Fullscreen Plugin (0.0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| ipOnConnect (0.2.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ipOnConnect
| Octolapse (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| !Palette 2 (2.4.13) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_palette2
| PrintTimeGenius Plugin (2.2.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2021-03-19 10:43:43,101 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| throttle_state: '0x0'
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2021-03-19 10:43:43,101 - octoprint.server - INFO - ------------------------------------------------------------------------------
2021-03-19 10:43:43,115 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-03-19 10:43:43,298 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-19 10:43:43,318 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-03-19 10:43:43,324 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-03-19 10:43:43,343 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2021-03-19 10:43:43,346 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyACM0, baudrate 115200
2021-03-19 10:43:43,350 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2021-03-19 10:43:43,371 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-03-19 10:43:43,380 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-19 10:43:43,413 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-03-19 10:43:43,477 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-19 10:43:43,649 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin bugfix-2.0.x (Sep 10 2020"
2021-03-19 10:43:43,746 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-03-19 10:43:43,743 - octoprint.plugins.ipOnConnect - INFO - ipOnConnectPlugin: M117 192.168.0.62
2021-03-19 10:43:45,378 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-03-19 10:43:45,381 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-19 10:43:45,381 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-19 10:43:45,566 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-03-19 10:43:50,817 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on CR10S._http._tcp.local.' for _http._tcp.local.
2021-03-19 10:43:51,648 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on CR10S._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-03-19 10:43:51,677 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on CR10S for SSDP
2021-03-19 10:43:51,767 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-03-19 10:43:52,502 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.72s
2021-03-19 10:43:52,905 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2021-03-19 10:43:53,833 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-03-19 10:43:53,835 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-19 10:43:53,836 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-19 10:43:54,047 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 11.7GB. That is considered sufficient for updating.
2021-03-19 10:43:54,075 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-03-19 10:43:54,160 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.3s
2021-03-19 10:43:55,843 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 1.3s
2021-03-19 10:43:56,835 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2021-03-19 10:43:56,847 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.67s
2021-03-19 10:43:57,242 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-03-19 10:43:57,245 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2021-03-19 10:43:57,247 - octoprint.plugins.dashboard - INFO - Dashboard started
2021-03-19 10:43:57,250 - octoprint.plugins.detailedprogress - INFO - OctoPrint-DetailedProgress loaded!
2021-03-19 10:43:57,254 - octoprint.plugins.themeify - INFO - Themeify initialized.
2021-03-19 10:43:57,264 - octoprint.plugins.ipOnConnect - INFO - ipOnConnectPlugin: M117 192.168.0.62
2021-03-19 10:46:07,621 - octoprint - ERROR - Exception on / [GET]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/views.py", line 667, in index
response = require_login(*default_permissions)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/__init__.py", line 383, in require_login
if not has_permissions(*permissions):
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/__init__.py", line 360, in has_permissions
flask.passive_login()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 710, in passive_login
user = login(determine_user(user))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 679, in determine_user
local_networks = _local_networks()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 615, in _local_networks
network = netaddr.IPNetwork(entry)
File "/home/pi/oprint/local/lib/python2.7/site-packages/netaddr/ip/__init__.py", line 938, in __init__
raise AddrFormatError('invalid IPNetwork %s' % addr)
AddrFormatError: invalid IPNetwork 192.168.0.1/255
2021-03-19 10:46:07,630 - tornado.access - ERROR - 500 GET / (fe80::ad5c:56f4:c2dc:b03b) 1447.99ms
2021-03-19 10:46:08,076 - tornado.access - WARNING - 404 GET /favicon.ico (fe80::ad5c:56f4:c2dc:b03b) 10.46ms
2021-03-19 10:46:15,359 - octoprint - ERROR - Exception on / [GET]
2021-03-19 10:46:15,367 - tornado.access - ERROR - 500 GET / (fe80::ad5c:56f4:c2dc:b03b) 55.58ms
2021-03-19 10:46:36,705 - octoprint - ERROR - Exception on / [GET]
2021-03-19 10:46:36,712 - tornado.access - ERROR - 500 GET / (::ffff:192.168.0.45) 46.26ms
2021-03-19 10:46:36,808 - tornado.access - WARNING - 404 GET /favicon.ico (::ffff:192.168.0.45) 9.31ms
2021-03-19 10:47:16,776 - octoprint.server.util.flask - INFO - Passively logging in user _api from fe80::14c2:d5db:7b4d:b46a
2021-03-19 10:47:16,778 - octoprint.access.users - INFO - Logged in user: _api
2021-03-19 10:47:16,998 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::14c2:d5db:7b4d:b46a
2021-03-19 10:47:17,139 - octoprint.server.util.sockjs - INFO - User _api logged in on the socket from client fe80::14c2:d5db:7b4d:b46a
2021-03-19 10:47:46,351 - octoprint - ERROR - Exception on / [GET]
2021-03-19 10:47:46,356 - tornado.access - ERROR - 500 GET / (::ffff:192.168.0.45) 28.26ms
Current version is 1.5.2
Everything was working fine a week ago, powered down, powered up today and can't connect. This is a wired connection, not a wireless connection.
If I ssh in, stop the server and restart the server I get the same result.
I see the following every time I refresh the web page...
2021-03-19 12:36:34,902 - octoprint - ERROR - Exception on / [GET]
2021-03-19 12:36:34,911 - tornado.access - ERROR - 500 GET / (fe80::ad5c:56f4:c2dc:b03b) 47.66ms
Other printers on the same network are fine (wireless connections)
Thoughts please?
