The adapter in the IO Broker keeps giving me the following error message and does not connect to the API.
octoprint.0
2022-02-18 16:28:45.938	info	timeout of 2000ms exceeded
octoprint.0
2022-02-18 16:28:35.923	info	timeout of 2000ms exceeded
octoprint.0
2022-02-18 16:28:15.891	info	timeout of 2000ms exceeded
octoprint.0
2022-02-18 16:28:05.894	info	timeout of 2000ms exceeded
octoprint.0
2022-02-18 16:27:55.888	info	timeout of 2000ms exceeded
A connection is therefore no longer possible.
I have already switched off or uninstalled several plug-ins.
However, all of this has had no effect.
I have already opened an issue for the OctoPrint adapter, where you can also find the more detailed logs from the IO Broker:
Git Hub Issues => Meldung "timeout of 2000ms exceeded" #70
The API connection to Heimdall works, apparently without problems.
Logs
Here is the log from my OctoPi:
octoprint (2).log (152.6 KB)
You can find the log of the IO Broker in the GitHub Issues.
Additional information about your network
I use a Unify network (switches, Acesspoint).
I use a Fritz Box 7490 as a router.
OctoPrint runs on a Pi 3 B+ which is powered by a PoE HAT.
IO Broker runs on an Intel NUC in a Proxmox VM.
