FLOREON IP CAM
Can you make octopi see an IP cam that not plugged into the pi but the same network
I tried putting the cam's IP address in to the settings
No log
Additional information about your setup (OctoPrint version, OctoPi version, ...) octoprint 0.18.0
I'm guessing no one knows
You may use the forums search function to get some hints?
Thanks for responding I didn't find anything which was why I asked
Have you had a look at the MultiCam plugin? Seems to do something very similar to what you want to do. I wanted to use a Pi Zero W running a camera in a self-contained case (to take the load off the OctoPrint Pi) and connect to it as a networked webcam rather than a direct-cabled USB camera or Pi camera. MultiCam seems to do what I intended to set up, and it should help you out too.
