iPad connects via wifi, I am able to to connect to octoprint, login, password all work fine, but octoprint UI never shows up on browser. No errors.
I have ssh'd into my octoprint, tailed "tail -f ~/.octoprint/logs/octoprint.log" # I can see all events that are being logged just fine. no user interface errors. It shows when my ipad logs in, no errors.
I added DEBUG to logging for environment, access, server and octoprint. Restarted octoprint.
set up tail on log (above) and attempted connection from ipad. Again, connection works, get login prompt, enter user and password, it logs in, I can see it in the logs, but nothing of the interface shows up except in the browser tab the title changes to "octoprint" as it should.
No.
N/A
Complete Logs
I tried to put in complete log, it would not allow me to do so, so I had to put in excerpt. Did not see a method to attach a log file.
2021-02-24 10:03:07,461 - octoprint.access.users - INFO - Logged in user: glennh
2021-02-24 10:03:07,465 - octoprint.server.api - INFO - Actively logging in user glennh from 192.168.10.253
2021-02-24 10:03:10,587 - octoprint.server.util.flask - INFO - Passively logging in user glennh from 192.168.10.253
2021-02-24 10:03:10,588 - octoprint.access.users - INFO - Logged in user: glennh
2021-02-24 10:03:10,808 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.10.253
2021-02-24 10:07:25,037 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-24 10:14:28,492 - octoprint.server.util.flask - INFO - Passively logging in user glennh from fdeb:dd78:6e81:0:1c0a:7d32:de0c:ee5f
2021-02-24 10:14:28,493 - octoprint.access.users - INFO - Logged in user: glennh
2021-02-24 10:15:02,162 - octoprint.server.util.flask - INFO - Passively logging in user glennh from 192.168.10.253
2021-02-24 10:15:02,163 - octoprint.access.users - INFO - Logged in user: glennh
Octoprint 1.5.3
Python 3.7.3
1 Peter 2:18-20;
Linux octoprint 5.10.11-v7+ #1399 SMP Thu Jan 28 12:06:05 GMT 2021 armv7l GNU/Linux
iPad: version 9.3.5 (13G36)
Model: FC769LL/A
IP: 192.168.10.253
iPad is up tod ate as much as it will allow. It's a gen 2 I think. And that may be the issue.
